Author Topic: Post your Korean Keyboard ^_^  (Read 13945275 times)
Offline dgneo
  • Supervillain
Re: Post your Korean Keyboard ^_^
« Reply #9950 on: Sun, 24 December 2017, 11:24:10 »
Offline SoftKeys
« Reply #9951 on: Sun, 24 December 2017, 11:54:15 »
Lightsaver v3
« Reply #9952 on: Sun, 24 December 2017, 12:03:47 »
Lightsaver v3
miami nights too good
Offline UsualSuspectXXX
  • (⌐■_■)⊃━☆゚.*・。゚
« Reply #9953 on: Tue, 26 December 2017, 01:03:07 »
Lightsaver v3
Lookin good man :thumb:
Offline zacheadams
« Reply #9954 on: Sun, 31 December 2017, 12:11:52 »
185554-0
« Reply #9955 on: Sun, 31 December 2017, 12:40:33 »
Offline zacheadams
« Reply #9956 on: Sun, 31 December 2017, 14:46:00 »
Offline mtzgr
    • My youtube
« Reply #9957 on: Sun, 31 December 2017, 16:48:08 »
Offline CommonCurt
  • One of the cool kids
  • 🍒 Beige or Bust
    • My Flickr Page
« Reply #9958 on: Sun, 31 December 2017, 17:25:55 »
I gotta get me a set of those black Cyrillic dyesubs  :thumb:
Some of Ye ole  Keyboards -->
WTB/WTS/WTT ---->
Offline MMKB
« Reply #9959 on: Mon, 01 January 2018, 18:20:57 »
British custom with Korean PCB.
X60 Founder Edition 02/30
185645-0
185647-1
A bit of backstory of how I finally fixed the stripped screw: search for a local handyman on Yelp.
And how he fix it: use a drill to slowly strip away the head of the screw piece by piece. Took one minute.
Offline MajorKoos
  • 1 life please. Extra large.
« Reply #9960 on: Mon, 01 January 2018, 18:39:12 »
Looks awesome.
Offline ctzn_voyager
« Reply #9961 on: Wed, 03 January 2018, 20:56:34 »
Beautiful. Glad you got the stripped screw sorted. I just received the acrylic plates for my X60 and will be rebuilding this weekend.
Offline MMKB
« Reply #9962 on: Wed, 03 January 2018, 23:02:04 »
Thanks! Look forward to your build. It's nice to be able to see the PCB  ^-^
The X60 GB thread has been locked but I still want to say thank you here to all the people who helped me on this.
Offline kiwi99
  • that's a gnarly dookie
« Reply #9963 on: Thu, 04 January 2018, 22:02:59 »
very nice :)
Offline LightningXI
  • PPD
    • ArtisanMacro
« Reply #9964 on: Thu, 04 January 2018, 23:56:35 »
Perhaps one of the boards I like the most. Not as brutal on the incline as the other models by this keyboard designer, but the layout and the design was always captivating to me. Certainly not as smooth as Khylnn's X60's anodization!
Duck Blackbird:
Offline crtexcnndrm99
  • *profile image used without permission* ;)
« Reply #9965 on: Fri, 05 January 2018, 01:08:37 »
Duck Blackbird:
There’s the layout, but everything else is
You're a smooth smoothie, you know? ~ Gaear Grimsrud
Offline vegs
« Reply #9966 on: Fri, 05 January 2018, 06:54:47 »
Very nice. Glad you got it fixed :)
What switches and plate did you use?
hhkb 4 life
buy less
Offline MMKB
« Reply #9967 on: Fri, 05 January 2018, 13:55:15 »
Thank you! Really like your X60 too!
Good ol lubed MX Blacks with SPRiT 68g springs. Smooth as butter. And aluminum plate.
Offline LightningXI
  • PPD
    • ArtisanMacro
« Reply #9968 on: Fri, 05 January 2018, 22:25:48 »
What do you use to lube your linear switches?  ;D
Offline MMKB
« Reply #9969 on: Fri, 05 January 2018, 22:33:06 »
The thin lube from SwitchTop.
  • (⌐■_■)⊃━☆゚.*・。゚
« Reply #9970 on: Tue, 09 January 2018, 20:21:34 »
Same. I've used it on gat blacks and will be using it on some cherry blacks soon.
Offline MMKB
« Reply #9971 on: Tue, 09 January 2018, 22:18:48 »
I heard on TopClack that you should use the Blacks first before lubing. That way they kinda get less scratchy first without the lubricant. I have no scientific way to confirm this but I didn’t follow the order and they seem a little scratchy. Time will tell I guess. My JD45 with exactly the same lubed switches is silk smooth after more than a year of use.
Offline limitz
  • "the old gods stir and will not let me sleep..."
« Reply #9972 on: Wed, 17 January 2018, 14:54:56 »
Playing dressup with the Ribbit.
Mmm... machined aluminum
Offline dubious
  • 쏘쿨
« Reply #9973 on: Wed, 17 January 2018, 14:58:02 »
One of my favorite OTDs!  :thumb: :thumb: :thumb:
Check this stuff out, works great for protecting brass from all those fingerprints
Offline dyrdevil
« Reply #9974 on: Wed, 17 January 2018, 15:08:14 »
Gorgeous!
Any pics of the back of that beauty?
  • (⌐■_■)⊃━☆゚.*・。゚
« Reply #9975 on: Wed, 17 January 2018, 16:31:40 »
I suppose it's not a bad suggestion, but I don't necessarily want to disassemble just to lube when I could have done it to begin with.
Offline LightningXI
  • PPD
    • ArtisanMacro
« Reply #9976 on: Wed, 17 January 2018, 17:18:01 »
What's the piece of plastic(?) you used on top of the 356mini weight? Where did you get it?
Offline pr0ximity
« Reply #9977 on: Wed, 17 January 2018, 17:35:19 »
Very cool, I've not heard of this before. Have you tried it on sand-blasted brass? Does it retain the matte look and texture?
I've been hesitant about using coatings like this because my understanding is they can be very difficult to remove if you don't like the results. But I'd prefer something like this over an iPad screen protector or simply letting it tarnish.
« Reply #9978 on: Wed, 17 January 2018, 17:36:29 »
sandblasted brass tarnishes, just not as quickly as polished brass
« Reply #9979 on: Wed, 17 January 2018, 17:42:51 »
My LS v3 with Nautilus alphas and Sky Dolch mods
Offline kiwi99
« Reply #9980 on: Wed, 17 January 2018, 20:51:31 »
wow this actually looks great, way better than regular nautilus. Great pictures too!
Offline dgneo
  • Supervillain
« Reply #9981 on: Thu, 18 January 2018, 06:57:58 »
Offline dubious
  • 쏘쿨
« Reply #9982 on: Thu, 18 January 2018, 11:58:23 »
I believe it is fairly easy to remove. Haven't tried it myself, but they have some solvents and instructions on their website. There is also a satin finish, and it sounds like they will custom mix it if you want something more matte.
Offline nasby99
« Reply #9983 on: Thu, 18 January 2018, 21:09:19 »
LOL..   it's so gorgeous... ^_^ ^-^
What I have currently
356CL(Black,Gun-metal), 356L, 356.2, 356DGE,356N MK2, 356MINI v1(military,red) 356MINI v2(red) 360c(apple silver,hyper blue),Koala,Cheat..
G81-3000SAV, G81-3100SAV,G81-3004SAT,G81-3000SAT,G81-3000SPBUS,G80-3000HAV,G80-2100HDU...
What I want to get now
Nothing atm
« Reply #9984 on: Fri, 19 January 2018, 01:12:43 »
FINALLY I GET TO POST MY OWN BOARD IN THIS THREAD
picture credit to lightningXI
MIRA SE in silver with GMK Soware, Bsun panda clears (bsun housing, mx clear stem, mx black spring), Zeal stabs
Best keyboard I've ever owned, by far. This board is incredible in person.
Offline MMKB
« Reply #9985 on: Fri, 19 January 2018, 01:30:56 »
Exited to hear what makes this board the best. Internals, dimensions, finish?
« Reply #9986 on: Fri, 19 January 2018, 01:40:29 »
all of it
it's all the things i like about 356 CL, plus a great diffuser and a more sensible firmware
Offline SixtyLife
« Reply #9987 on: Fri, 19 January 2018, 10:56:19 »
your F12 doesn't look fully seated  ;)
Kishsaver, JP SSK, Displaywriter SSK, 360C, HHKB Type S, X60, Jane v2, Jane v2 CE
« Reply #9988 on: Fri, 19 January 2018, 11:13:37 »
u right
It's good now
Offline MajorKoos
« Reply #9989 on: Fri, 19 January 2018, 11:35:25 »
Nice jealousy item.
Offline maxf
« Reply #9990 on: Fri, 19 January 2018, 11:50:53 »
Viper v2
« Reply #9991 on: Fri, 19 January 2018, 13:10:45 »
Nice jealousy item.
types even better than it looks
Offline Kellybear
  • (づ。◕‿‿◕。)づ
« Reply #9992 on: Fri, 19 January 2018, 13:13:29 »
You took so long building this I fell asleep :c Looks fantastic though!
« Reply #9993 on: Fri, 19 January 2018, 13:14:26 »
yeah and i ****ed the LEDs up anyway, haha
but it turned out awesome
Offline pr0ximity
« Reply #9994 on: Fri, 19 January 2018, 18:55:55 »
Offline [Lewynlight]
  • Formerly Dymloslouire
« Reply #9995 on: Fri, 19 January 2018, 23:53:19 »
 :p
TGR Jane V1 CE - TGR Jane V2 CE Black Ano - TGR 910 R1 - TGR 910 RE Polycarbonate - TGR 910v3 Prototype - TGR Tris - RS60 - RS65 "Internet Yamero" - RS TKL
Offline Giorgio
« Reply #9997 on: Sat, 20 January 2018, 04:54:26 »
 :p
Nice one! Intensely red, that's quite rare.
But... how can you live without windows keys? What remapping do you use?
Another thing.... when pressing those 1.5 modifier keys, do you feel like the coud need some stabilization or not?
Offline icyskyz
« Reply #9998 on: Sat, 20 January 2018, 05:21:15 »
Living without windows keys isn't as bad as you thought actually.
I usually remap the windows key to the right ALT on my 360 as well as my other WKL kustoms (right ALT key is that key I rarely or never use :))).
Personally, I think it's totally fine without a stabilizer even it might wobble a little more than other keys.
My collections - flickr | HWS Keyng Collector |
« Reply #9999 on: Sat, 20 January 2018, 09:14:42 »
New shoes on the Viper
