Author Topic: Swapping Switches on a Leopold FC200R  (Read 3606 times)
Offline kwago
« on: Mon, 24 September 2012, 22:23:12 »
Is it possible to replace stems and springs without removing the entire switch from the PCB? I want to swap out some of the Red switches with something more stiff.
Offline Appeac
Re: Swapping Switches on a Leopold FC200R
« Reply #1 on: Mon, 24 September 2012, 22:28:46 »
No, it's plate mounted so you'll have to desolder.
It's a pretty easy to do if you watch some soldering youtube videos.
FC660C
122 Terminal M w/ Soarer board
Offline kwago
« Reply #2 on: Mon, 24 September 2012, 22:32:01 »
Ahh, too bad. Well soldering wouldn't be too bad. Thanks for the quick response :D
Offline Appeac
« Reply #3 on: Mon, 24 September 2012, 22:54:04 »
I did my Ergo clear mod about 2 weeks ago. Took me about 4-5 hours total. That's desoldering 87x2 switches, switching 87x2 springs, and resoldering 87x2 switches back in.
FC660C
