Author Topic: Looking for keycaps for CapsLock & Ctrl swapping  (Read 1495 times)
Offline megnin
  • Trade Count: (0)
  • Topre, or not Topre? That is the question.
« on: Tue, 25 September 2012, 08:32:26 »
Since using HHKB 2 Pros for a while, I've gotten used to swapping the CapsLock and Ctrl keys on any keyboard that I use.
Now I'm looking for keycaps with the legends swapped appropriately for various keyboard models.
Most use the standard (Filco, etc.) size caps so that size may serve 100% of my needs.  It looks like the Ducky Year of the Dragon and KBT Pure both use standard size caps.
Anyway, I'm looking for 1x1.25 caps with "Caps" printed and 1.1.75 caps with "Ctrl" printed on them.
Keys for backlit boards would be nice.  Any white(ish) on black.  I could also use black on white.  I already have plenty of blanks so I don't need blanks.
If you have any you'd part with or even know where I might find them, drop me a message.
“The only difference between me and a madman is I'm not mad." -- Salvador Dali
Offline oneproduct
  • Trade Count: (0)
  • @Ubisoft
Re: Looking for keycaps for CapsLock & Ctrl swapping
« Reply #1 on: Tue, 25 September 2012, 09:00:49 »
wasdkeyboards is what comes to mind right away, though I imagine you already knew about them and are looking for something else.
Layout: Colemak
Offline megnin
  • Trade Count: (0)
« Reply #2 on: Tue, 25 September 2012, 17:09:09 »
I hadn't thought of wasdkeyboards.  I should have looked there first, maybe.  Thanks!
