Author Topic: looking for G80-3000LSCXX-00  (Read 2545 times)
Offline kinruan
  • SWAG=Specially Weaponized Asian Grandma
« on: Tue, 25 September 2012, 14:27:17 »
this is a non-printed version of G80-3000 which is white and has nothing on the up cover/case also. do anyone know where can i find it? seems it is out of stock everywhere except a 180$ website.
« Last Edit: Tue, 25 September 2012, 16:43:23 by kinruan »
If the world ends tomorrow, what should we have for dinner tonight?
Offline IvanIvanovich
  • Mr. Silk Underwear
Re: looking for G80-3000LSCXX-00
« Reply #1 on: Tue, 25 September 2012, 14:43:47 »
keyboardco has G80-LPCXX-2 which is blacks version for $112. The blank S with blues is really difficult to find except for Das II which is the same thing. Also never seen ANSI version of white blank XX, I think it was only made in ISO XY.
« Last Edit: Tue, 25 September 2012, 14:46:30 by lysol »
Offline limmy
« Reply #2 on: Tue, 25 September 2012, 14:55:46 »
I have ANSI layout beige(white) blank PBT caps from Cherry. They are frequently traded in Korean market at around $30~40.
You could get printed version and get the blank caps.
Offline kinruan
« Reply #3 on: Tue, 25 September 2012, 16:38:52 »
oh yeah, it is XY, both are fine since i can make PCB changes. do u know anywhere i can find it? i just want the white one.
« Reply #4 on: Tue, 25 September 2012, 16:56:23 »
I think I mixed up XX and XY... keyboardco used to have both black and white in ISO I think, might ask them if they will have more in stock. Otherwise the only other place I have seen them for sale is TaoBao.
Offline kinruan
« Reply #5 on: Tue, 25 September 2012, 19:28:27 »
taobao is all out of stock or with the unreasonable price.
Offline sth
  • 2 girls 1 cuprubber
« Reply #6 on: Tue, 25 September 2012, 19:32:17 »
I can hook you up with a g81-3000 case that has no decals/logos ( have a few, actually) that is more or less compatible with a g80-3000 after some slight modifications. I did that myself with one of them. you would have to track down a g80-3000 with blues though.
Offline kinruan
« Reply #7 on: Tue, 25 September 2012, 19:40:01 »
thank u. let me think about it. good idea to make it myself :)
