Author Topic: Is it possible to mod 8 keys from an HHKB Pro2 from 45g to 55g?  (Read 1667 times)
Offline TacticalCoder
« on: Wed, 26 September 2012, 15:25:25 »
I love my HHKB Pro2 but I do touch-type and I do actually rest my fingers on the keyboard when I'm not typing. So sometimes I accidentally trigger, say, 'k' without even noticing it. It may just be because I'm not yet used enough to my HHKB (after years spend using Model Ms).
Would it be possible to mod the 8 keys: asdf and jkl; to 55g?
If it's possible, is it "easy"?
Would it feel ok or do you think it would feel too weird to have such a variable-force layout?
Offline SmallFry
Re: Is it possible to mod 8 keys from an HHKB Pro2 from 45g to 55g?
« Reply #1 on: Wed, 26 September 2012, 15:57:57 »
Possible yes... It will cost you that MX 5000 though! :P
It is probably not too hard... though I don't own a Topre board to test it with.
Offline alaricljs
  • I be WOT'ing all day...
« Reply #2 on: Wed, 26 September 2012, 16:35:12 »
I believe hasu has done something similar.  It consists of buying a donor board and cutting the 2 dome sheets and putting everything back together.  Not cheap.
Filco w/ Imsto thick PBT
Offline SmallFry
« Reply #3 on: Wed, 26 September 2012, 17:07:13 »
QFT. I wouldn't recommend it.
