Author Topic: I user a poker w/ Black to program at work with...  (Read 2399 times)
Offline Mainian
« on: Fri, 28 September 2012, 12:21:42 »
Am I doing it right?
 :cool:
Offline boost
  • BOSTMOBILE
  • NY Giants!!!
Re: I user a poker w/ Black to program at work with...
« Reply #1 on: Fri, 28 September 2012, 12:26:02 »
Yes you are :)
I rotate MX-Mini with 50g Blacks and CM Storm with MX BLues
-Enzo Ferrari
Offline wiredPANDA
« Reply #2 on: Fri, 28 September 2012, 12:41:29 »
I'm trying to learn the Fn layer, so I can actually get work done on the Poker.  Making me realize how much I use the arrow keys and delete when I'm writing automation scripts.
| HHKB Pro 2 | Leopold FC660C
| Poker.PANDAclears | ErgoDox (62g Black)
Offline proest
« Reply #3 on: Fri, 28 September 2012, 13:24:04 »
Yes! As long as I agree with your choice of text editor, that is...  :D
Offline Mainian
« Reply #4 on: Fri, 28 September 2012, 13:25:21 »
Yes you are :)
I use filco majestouch-2 w/ blue and dampening switches at home. I'm a student, so I spend MUCH more time coding on home computer for projects. (Also, I use a macbook pro about the same amount as I do my desktop). So I guess I see scissor switches / blues about the same.
It wasn't too bad... to be honest, the most useful ones for coding are the f5 / f11 / f12 xD.
and of course ctrl-alt-fn-(z or /) and I almost ALWAYS keep the arrow keys turned on when doing ANYTHING on the poker.
Using notepad++ right now to make some mock Oracle SQL since I know very little about Oracle SQL. Basically copying and editing some prior code and showing it to someone who understands SQL much better than me before I drop it in the DB.
« Reply #5 on: Fri, 28 September 2012, 13:58:36 »
Notepad++ is the best text editor on Windows IMHO.  On Unix/Linux if you aren't using Vim you're dead to me :p
Offline alaricljs
  • I be WOT'ing all day...
« Reply #6 on: Fri, 28 September 2012, 14:16:02 »
So why aren't you using vim on windows?
Filco w/ Imsto thick PBT
« Reply #7 on: Fri, 28 September 2012, 14:33:58 »
Because Notepad++ is better.  I've long been conflicted about that very point.  When it comes right down to it, though, Vim just feel out of place on that platform.  Emacs does a little better, but homey don't play that.
Offline salmo
    • messmore.org
« Reply #8 on: Fri, 28 September 2012, 21:47:04 »
I used my Race with reds at work for a while (until the LEDs got kinda flakey), and spend most of my day writing scripts and poking at stuff on a terminal.
I could probably do without the arrows, since I'm pretty much always in vim or using vi-mode in the shell. But, I think the ~/esc issue would bother me more.  I use backticks a lot in m4, '~' interactively, and I beat the fool out of my esc key.
Offline wiredPANDA
« Reply #9 on: Fri, 28 September 2012, 21:55:34 »
That's what broke me today, salmo.  The esc/tilde battle.  I had to switch back to Leo TKL to get through the last half of the day.
I'm going to retire it to my house; at least until I get used to the function layer or I get a AHK config setup.
