Author Topic: Home-made palmrest.  (Read 16946 times)
Offline boxjon
Home-made palmrest.
« on: Fri, 28 September 2012, 14:52:29 »
Got inspired looking at some of the pics of workstations. Went straight to Lowes and got me some plywood and sandpaper. It feels baby smooth and its only 1 inch tall, so perfect height for typing.
« Last Edit: Fri, 28 September 2012, 14:54:07 by boxjon »
Corsair K60 | Corsair M90
Offline modulor
Re: Home-made palmrest.
« Reply #1 on: Fri, 28 September 2012, 14:59:20 »
Nice, you should stain and/or seal it next!  I'd recommend a few coats of tung oil.
NP-R (soon) | 21XX | Leggera-G Acrylic | Classic TKL | Frog TKL 8K | GH60revC | R1 86U 45g | G80-2100HDU | G80-3000HAU | G80-3700HAU | QFR V1 | FC200R | Poker X | G80-11900LUMEU
Offline boxjon
« Reply #2 on: Fri, 28 September 2012, 15:04:46 »
Great suggestion. I liek the smooth feel of the sanded raw wood. Would the stain eliminate that feeling?
Offline modulor
« Reply #3 on: Fri, 28 September 2012, 15:13:53 »
Stain won't change the texture, as it gets absorbed into the wood.  Tung oil is the same way, but it will seal the wood and make it liquid-proof, plus give it a nice luster without altering the texture much (unless you apply alot).  I figured you'd prefer that better than sealing it with a clear coat or varnish. Plain tung oil will darken the wood slightly (imagine a damp look) but I think you can also get it tinted or 'with stain'.  It will also strengthen the wood.  I've used tung oil in the past for furniture and it works great. ;D
Offline boxjon
« Reply #4 on: Fri, 28 September 2012, 15:16:02 »
Well in that case I might be making another trip down to Lowes. Does it take long for this stuff to dry? Also would like to etch something in the corner, need to find a way to do that.
Offline boxjon
« Reply #5 on: Fri, 28 September 2012, 15:28:16 »
Ok, so, I have another piece of wood cut to the same dimensions. I will apply the oil this weekend. I am also planning on buying a small burning tool to etch some writing near the bottom right hand side. Made it look a bit pro. I'll post pics as soon as it's done.
Offline modulor
« Reply #6 on: Fri, 28 September 2012, 15:30:37 »
What you'll probably find at Lowe's is 'Tung Oil Finish' which is similar, but not actually tung oil.  I had to find 100% tung oil online, but I've used both and the 'Finish' is easier to work with and will give you a similar effect.  It's basically wiping varnish, so it will still be applied and absorbed into the wood and seal the same way. Pure tung oil requires a distiller like turpentine.  http://en.wikipedia.org/wiki/Tung_oil#Application
Also, I think you have to wait 24 hours between coats for either option, but you may be satisfied with just one coat.
« Last Edit: Fri, 28 September 2012, 15:41:16 by modulor »
Offline modulor
« Reply #7 on: Fri, 28 September 2012, 15:40:35 »
Alssso...welcome to GeekHack! :D
Offline dreamingftw
« Reply #8 on: Sat, 29 September 2012, 14:30:10 »
Good idea, might head to my local lowes or home depot to make one myself.
Offline boxjon
« Reply #9 on: Sat, 29 September 2012, 14:49:22 »
The piece I bought was literally like 2 bucks. I have plenty left over. I used 2, 8inch pieces to prop my computer up from the carpet (better ventilation) and I still have about another 3-4 feet of it in the Jeep. Although I might used it for something today. Got that, "I gotta build something" itch I need to scratch.
Offline dreamingftw
« Reply #10 on: Sun, 30 September 2012, 00:11:36 »
I just made my own wrist rest but I can't post the pictures. Weird. I'll try to post em tomorrow. Thanks for the idea!
Offline boxjon
« Reply #11 on: Sun, 30 September 2012, 07:18:09 »
You have to upload the pics somewhere online, like Picasa and then right click on the picture COPY THE IMAGE URL, then post it here between this . If you already knew that I apologize. It's hard to grasp know-how over the internets.
Offline dreamingftw
« Reply #12 on: Sun, 30 September 2012, 11:33:26 »
Finally figured out how to post my pictures, thanks for the help. The width on the rest is a little short for me because I have bigger hands so I need to adjust it a little bit further away from the keyboard, which is fine. I might make another one, which would probably only cost a couple more bucks. I'm liking the wood feeling so far. I was also planning on staining it but not sure yet. I also added rubber stoppers I got from my sub woofer, which lift it the perfect height. Thanks again for the ideas and insight!  ;D
Offline boxjon
« Reply #13 on: Sun, 30 September 2012, 12:27:19 »
Thats a lot nicer looking then mine. lol
What keyboard is that. Looks nice.
Offline dreamingftw
« Reply #14 on: Sun, 30 September 2012, 13:20:37 »
Thanks, its a cooler master QFR mx reds.
Offline dreamingftw
« Reply #15 on: Sun, 30 September 2012, 13:31:42 »
This is the one I stained last night.
Offline modulor
« Reply #16 on: Sun, 30 September 2012, 17:05:23 »
Looking good!  Now I'll have to give it a go ;D
Offline boxjon
« Reply #17 on: Mon, 01 October 2012, 07:58:54 »
Yeh, stain them quick, mine now has some yellowing where my hand was, hopefully the stain covers that up a bit, if not I can easily make another.
Offline huttala
Sv: Re: Home-made palmrest.
« Reply #18 on: Sat, 06 October 2012, 22:31:13 »
Or you could just sand it clean before applying oil.
Sent from my Samsung Galaxy Note II using Tapatalk.
Offline modulor
« Reply #19 on: Sat, 06 October 2012, 22:51:26 »
A dark stain would cover it up, but sealing the wood would definitely prevent this in the future.
