Author Topic: For White (Beige) Case Filcos, White or Black PBT Keycaps?  (Read 13675 times)
Offline Hyde
  • White Tofu Extraordinaire
« on: Sat, 29 September 2012, 11:05:45 »
Hello I currently own a White (Beige) Filco Ninja MX Red 104 key.  But I'm considering to jump into the world of PBT keycaps since I've noticed for MX Red's the keycap material effects the feel of switch quite a bit.  Even black ABS keycaps feels more solid than their default beige counterpart (I'm guessing black has higher density).
But now the issue is since I know white PBT keycaps are generally super white, and filco is more like beige.  So I've seen some picture on the internet and know they colour will not match up.  So would it be better (or even more stylish) for me to go with black PBT keycaps?
I know I want to try blank set so engraved/top printed/side printed won't be taking into consideration here.  Personally I like the current look but too bad they don't sell Filco beige tinted PBT keycaps.
So what do you guys think?  White PBT or Black PBT?
Current Setup:
« Last Edit: Mon, 01 October 2012, 21:10:40 by Hyde »
Re: For White (Beige) Case Filcos, White or Black PBT Keycaps?
« Reply #1 on: Sat, 29 September 2012, 13:48:05 »
I think you can get cherry lasered PBT in off white. This may well be your best option, as it's super cheap on ebay (Even for a new set)
Although it's their newer thin PBT, my White G80-8113 has off white lasered PBT.
« Reply #2 on: Sat, 29 September 2012, 15:14:20 »
Is Cherry's off-white really the same hue as Filco? I am not sure about that. Even then, there are going to be problems with Caps Lock and Space Bar.
To answer the question:
* Black keys do look good on a white keyboard.
* If you get super-white keys, you could paint the case to match but then it won't have a textured surface any more and you can't go back. A waste on a white Filco in my opinion.
Offline swagpiratex
« Reply #3 on: Sat, 29 September 2012, 15:44:00 »
I would wait for the beige set from imsto, whenever he gets those back in stock.
« Reply #4 on: Sat, 29 September 2012, 16:15:24 »
In my opinion, black keys on a white board look hot.
Offline Hyde
« Reply #5 on: Sat, 29 September 2012, 16:16:26 »
Ohhhh does imsto have a page somewhere or is it from eBay?  Or should I PM him?
As for the cherry set yeah I'm worry about the capslock and spacebar, I have no experience with modding :(
I also considered grey or blue before (even though they're lettered), but in the end I think grey and blue might look cool initially but I'm not sure if I'll get sick and tired of it after a while.  I'm trying to steer away from the crazy gamer look I think I like it simple and elegant kind of look :P
Grey:
http://www.ebay.ca/itm/KBC-Gray-Dyesub-Thick-PBT-Cherry-MX-Key-Caps-105-keys-included-/230852256384?pt=PCA_Mice_Trackballs&hash=item35bfdde280#ht_500wt_1414
Blue:
http://www.ebay.ca/itm/KBC-Blue-Dyesub-Thick-PBT-Cherry-MX-Key-Caps-105-keys-included-/330758846871?pt=PCA_Mice_Trackballs&hash=item4d02c37997#ht_500wt_1414
Blue Blank:
http://www.ebay.ca/itm/KBC-Blue-Blank-Thick-PBT-Cherry-MX-Key-Caps-105-keys-included-/230820640143?pt=PCA_Mice_Trackballs&hash=item35bdfb758f#ht_500wt_1414
Thanks for the suggestions guys !
Offline WhiteFireDragon
    • youtube
« Reply #6 on: Sat, 29 September 2012, 23:35:08 »
If you can get a hold of a "red alert" set with grey modifiers, it would look pretty awesome. The grey modifiers match the color of the white filco case. This is Dan's filco with those mentioned caps:
Offline Lethal Squirrel
  • I <3 60%
« Reply #7 on: Sun, 30 September 2012, 00:07:29 »
In my personal opinion, black caps look absolutely sexy with a white case.
« Reply #8 on: Sun, 30 September 2012, 00:13:08 »
{img}
niiiice
Offline Megaweapon
« Reply #9 on: Sun, 30 September 2012, 15:13:54 »
Does the RK-9000I use the "Filco white" body or is it bright white?
http://www.newegg.com/Product/Product.aspx?Item=N82E16823201052
The photos make it look bright white, but that's an easy thing for photos to be wrong about.
Ancer Research Groop DFK191ABA11 • IBM Model M13 Part 92G7461 (white) • Rosewill RK-9000
Matias Tactile Pro 3 • Apple Extended Keyboard II (ALPS)
• Rosewill RK-9000I
Offline Hyde
« Reply #10 on: Sun, 30 September 2012, 22:42:41 »
lol ok I'll leave the black PBT as my last resort.  Though I noticed the grey and blue PBT keycaps are Cherry replica.  So is it safe to assume that they might replicate the beige color one day too...?  Maybe I'll be patient and wait a bit  :)
EDIT:  lol omg I just found out about the imsto's sub forum I'm such a noob.  Never know those exists !  But yes I saw the post where he said beige will be available later  :D
« Last Edit: Mon, 01 October 2012, 09:03:55 by Hyde »
Offline ficklampa
    • My photography portfolio
« Reply #11 on: Mon, 01 October 2012, 07:32:05 »
images from http://www.qwerkeys.co.uk
 These would look awesome on a white keyboard. Maybe not exactly that colour but I love the design
Filco TKL (mx browns) + Ducky PBT caps
Poker II (mx blues)
Keycool 22 key numpad (blue Kailh)
Offline Hyde
« Reply #12 on: Mon, 01 October 2012, 20:56:53 »
I like the blue power button key, look quite nice but I wonder if it would look too busy if it's like that style across the whole board :P
Oh and now that I find out imsto might carry beige keycaps later.  Now I can't decide if I want blank or beige + blue lettering =_______=
Blank (Image found on internet):
5314-0
Blue Lettering (Image from imsto's vendor forum, the mix of blue and beige is optional you can get all blue or all beige.  In my case I want all beige):
5316-1
All blank has this what I call "white tofu" look and it look simple.  But I'm a sucker for blue lettering noooo what to do ~
« Last Edit: Mon, 01 October 2012, 21:02:00 by Hyde »
Offline swagpiratex
« Reply #13 on: Mon, 08 October 2012, 12:15:45 »
When it's difficult between the two, then you punish your brain by getting both. If it rationalizes and realizes that you're investing $180 for 200 little pieces of plastic, then it becomes easier to choose which one you really want. If it still wants both, then you have the option of switching them out when you're bored. Up to how much you're able to spend, really.
Offline Hyde
« Reply #14 on: Tue, 09 October 2012, 14:51:11 »
lol I know I can only afford one set, that and I still want to try buckling spring and topre can't spend all my money on keycaps :P
Now I'm just debating how long I should wait, sounds like this could take MONTHS before anything happens >_____>
Let's see how long I can wait before I jump the gun and just buy whatever color's available lol
Offline josh
  • Since 2011
« Reply #15 on: Fri, 12 October 2012, 11:44:04 »
nice mouse pad,I also have one
OTD 356CL Gunmetal | OTD 356CL Black | OTD 356CL DGE | OTD 356 Mini Military Green | OTD 356 Pad | TGR Jane V2 Blue Grey | TGR Jane V2 Pink | TGR Jane V2 ce E-White | TGR Alice Prototype 1.0 | TGR Alice Pink Silver Two Tone | TGR Alice Polycarbonate | TGR 910 RE Red | TGR 910 ce Silver | TGR x GAF 910 Black | TGR x GAF 910 Purple | Noxary Vulcan Pro Silver | Noxary Evija HG | Keycult No.2/65 Unfinished Red | Realforce 101 | Realforce 10 Year Anniversary | Realforce 23U | HHKB Professional White | HHKB Professional Charcoal | HHKB Snow 25th Anniversary Japan Edition
Offline Hyde
« Reply #16 on: Sun, 14 October 2012, 19:16:21 »
lol yeah Artisan Shiden is the best of both worlds from soft to hard mouse pad.
Oh another note, I got impatient and jump the gun on this group buy http://geekhack.org/index.php?topic=31861.0
I went for the blank set, the colour might not be the perfect shade / match but I think this is the best choice I have at the moment to get cherry profile thick PBT keycaps for my Filco  :P
Offline Hyde
« Reply #17 on: Thu, 18 October 2012, 19:21:02 »
lol nvm in the end I decide on blue on white dye sub, since it's avaiable as new option now.  I think I just like blue too much LOLLLL
Offline zzAaron
« Reply #18 on: Sun, 21 October 2012, 01:14:29 »
post pics when you get em!
Ducky 9008G2 Browns, White Filco TKL Reds
Offline Hyde
« Reply #19 on: Sun, 21 October 2012, 22:05:33 »
lol sure I'll let you guys know if I get them, though now we're at 170/300 MOQ so if we can magically make it through then it would awesome >____>
