Author Topic: Looking for side printed PBT caps for my Pure  (Read 2653 times)
« on: Sat, 29 September 2012, 21:34:40 »
Specifically some white ones. If anyone could point me in the right direction I would greatly appreciate it.
Offline TheProfosist
  • Custom Layouts Only!
Re: Looking for side printed PBT caps for my Pure
« Reply #1 on: Sat, 29 September 2012, 23:03:46 »
Check out qtan's subforum, store, or his ebay. I have bought both black and white side printed pbt sets from him.
« Reply #2 on: Sun, 30 September 2012, 02:34:24 »
Offline WhiteFireDragon
    • youtube
« Reply #3 on: Sun, 30 September 2012, 02:38:01 »
He asked for PURE though. That keyboard has the shorter right shift, which you can only get with a SP set + tsangan kit, but SP does not do side printing. All standard sets from imsto, qtan, and feng are for ISO layouts. Your only option for the PURE is to not be a perfectionist and accept the right shift and the extra x1 key next to the right shift to not be side printed.
« Last Edit: Sun, 30 September 2012, 02:39:51 by WhiteFireDragon »
« Reply #4 on: Tue, 02 October 2012, 01:29:27 »
Didnt qtan also sell the pure he should probably be able to get a cap set for it also.
