Author Topic: Post your rig  (Read 236968 times)
Offline hehenri
Re: Post your rig
« Reply #350 on: Mon, 12 May 2014, 10:46:12 »
i5 3570K @4,5GHz | Maximus V Gene | GTX 780 Ti | Vengeance 16 Gb | Samsung 840 Pro 512GB :)
nice!!!
Thanks! :)
Offline SaySo
Re: Post your rig
« Reply #351 on: Mon, 12 May 2014, 10:49:55 »
« Last Edit: Tue, 03 July 2018, 12:35:51 by SaySo »
Offline microsoft windows
  • Blue Troll of Death
  • President of geekhack.org
    • Get Internet Explorer 6
Re: Post your rig
« Reply #352 on: Mon, 12 May 2014, 13:13:01 »
Kenworth W900.
Offline Smeagol_RP
  • your ad here
    • Steam
Re: Post your rig
« Reply #353 on: Mon, 16 June 2014, 17:41:51 »
Bought a new card. So I had to make a little mod to avoid an overheated VGA.
  • CM QFR (Clears) | CM QFR (Blues) | KBT Poker II (62g Browns) | CM Alcor
Offline Frenir
  • HHKB Viking
Re: Post your rig
« Reply #354 on: Mon, 16 June 2014, 17:52:11 »
Offline HPE1000
  • Keycap Paparazzo
Re: Post your rig
« Reply #355 on: Mon, 16 June 2014, 17:56:29 »
Sabertooth too good, practically blends in with the case. What cards are those? 670?
Offline Frenir
  • HHKB Viking
Re: Post your rig
« Reply #356 on: Mon, 16 June 2014, 18:00:23 »
Those are 660's  :-X
I should get a new card.
Offline HPE1000
  • Keycap Paparazzo
Re: Post your rig
« Reply #357 on: Mon, 16 June 2014, 18:26:18 »
Those are 660's  :-X
Still awesome, sli 660ti is a beast setup. I need to upgrade soon as well, singe 670 and I try to do 5760x1080 all the time, it works out mostly. Once gta v comes out I will decide  :p
Offline kishagi
  • Narcoleptic
Re: Post your rig
« Reply #358 on: Mon, 21 July 2014, 17:14:57 »
Intel Core i7 3770k (Delidded) |ASRock Fatal1ty Z77 Professional-M |Samsung Green 30nm 16GB
PNY & Galaxy Geforce GTX 670 2GB |Scythe Mugen 3 Rev.B / Phobya UC2-LT Nickel |ASRock Game Blaster Soundcard/NIC
Offline TLSC.wipeOut
  • "Who dares, wins"
Re: Post your rig
« Reply #359 on: Tue, 22 July 2014, 11:02:30 »
Dont think I've ever shared my current pc
http://s1248.photobucket.com/user/jokrik89/slideshow/Project%20Blank/Project%20Blank%20Final
That is so sexy... *drools*
OTD 456GT with Lubricated 68g Gold Spring MX Clears and GMK Dolch Keycap set
WTB: KMAC2 kit
Offline cmadrid
Re: Post your rig
« Reply #360 on: Tue, 22 July 2014, 12:28:31 »
Slightly different now.. I was opening it up to put in 2 256gb Crucial MX100 ssds. With the side panel back on you can't see the hard drive area, only the top section of the case.
3570k @ 4.6ghz
8gb ram
4gb EVGA gtx680 w/ backplate
Offline Heezy
  • Formerly trynds
Re: Post your rig
« Reply #361 on: Tue, 22 July 2014, 12:50:55 »
3570k @ 4.6ghz
8gb ram
What casing is that?
Rig - i3 6300, 240GB SSD, 500GB SSD, Gigabyte H170N Wifi, 16GB DDR4, Zotac 1060 Mini, 650w SuperFlower
Monitor - HKC144hz Mouse/Mousepad/Keyboard - Zowie EC1A - Zowie GS-R - Zowie Camade - Filco TKL MX Pink
Offline cmadrid
Re: Post your rig
« Reply #362 on: Tue, 22 July 2014, 12:53:53 »
Caselabs Mercury S5 mATX Red on White.. matches my keyboard and mouse too!  Just need to finish my QFR top case replacement.  Then I will have to figure out how to get a Conservative Red and Canada v2 mx >_<
edit: and get around to ordering a custom USB cable when it fits into the budget ;)
Offline Heezy
  • Formerly trynds
Re: Post your rig
« Reply #363 on: Tue, 22 July 2014, 13:04:22 »
Ah a caselab. I'm looking around for a rather small casing for my mini itx. Currently using Bitfenix Prodigy, and it's a little big for me.
Offline cmadrid
Re: Post your rig
« Reply #364 on: Tue, 22 July 2014, 13:06:30 »
Ya, this is bigger than a Prodigy.. they have a mITX version, but I don't think it would be small enough for you either
  • "Who dares, wins"
Re: Post your rig
« Reply #365 on: Tue, 22 July 2014, 14:54:09 »
3570k @ 4.6ghz
8gb ram
thats a nice clean look cmadrid~ =)
WTB: KMAC2 kit
Offline cmadrid
Re: Post your rig
« Reply #366 on: Tue, 22 July 2014, 15:19:19 »
Thanks!  Cleaned up the cables a bit, when I'm feeling less lazy I need to put a couple self adhesive cable clamps in there and get things locked down ;)
Offline koalapear
  • Actually hates koalas.
Re: Post your rig
« Reply #367 on: Tue, 22 July 2014, 15:32:46 »
4670k @ 4.0Ghz
8GB of RAM
GTX 780
1440p X-Star Main Monitor, 1200p Dell Secondary Monitor
'91 Model M SSK | NerD 60 (MX Greens) | Realforce 87U 55g | Winkeyless B.87 (MX Greens) | Monarch Matias Custom | HHKB | Duck Octagon (67g Zealios)
Offline cmadrid
Re: Post your rig
« Reply #368 on: Tue, 22 July 2014, 15:35:36 »
That noctua theme!
Re: Post your rig
« Reply #369 on: Tue, 22 July 2014, 18:37:39 »
3570k @ 4.6ghz
8gb ram
The mobo sits flat!
I haven't seen that in a tower (more or less) case before.
I have a couple of double-width cases, but the mobo is vertical on one side and the other side is designed for 8 or 10 HDD to be mounted one above the other.
Offline cmadrid
Re: Post your rig
« Reply #370 on: Tue, 22 July 2014, 19:44:40 »
Yeah, they have horizontal motherboard try cases for mITX, mATX, and ATX at Caselabs, as well as more traditional layouts.. pretty much anything you could want.  They have cases you can get inside of and close the panel behind you lol
Offline cmadrid
Re: Post your rig
« Reply #371 on: Tue, 22 July 2014, 19:47:03 »
Oh, and one of your posts is on my monitor in the 2nd picture I posted, lol
Offline Kraksx
Re: Post your rig
« Reply #372 on: Tue, 22 July 2014, 20:27:00 »
4670k @ 4.0Ghz
8GB of RAM
GTX 780
Saw this on reddit a long time ago. Thought you were going to be a bundle of sticks, Checked the username. Same username. Good Guy OP
Poker II
Offline cmadrid
Re: Post your rig
« Reply #373 on: Tue, 22 July 2014, 20:32:00 »
um.. I am confused :o
Offline Jokrik
Re: Post your rig
« Reply #374 on: Tue, 22 July 2014, 20:41:09 »
Saw on facebook, caselabs have something smaller coming
Pretty sure I'm gonna pick up my second caselabs case when it release :p
Offline cmadrid
Re: Post your rig
« Reply #375 on: Tue, 22 July 2014, 20:46:11 »
+1
Offline ApocalypseMaow
  • Kitteh Overlord
  • Say WHAAT...
Re: Post your rig
« Reply #376 on: Thu, 24 July 2014, 14:39:45 »
3570k @ 4.6ghz
8gb ram
Oh that S5 is hot!!!
Offline cmadrid
Re: Post your rig
« Reply #377 on: Thu, 24 July 2014, 18:46:32 »
aaaand I won it in their Christmas giveaway last year :o
  • Kitteh Overlord
  • Say WHAAT...
Re: Post your rig
« Reply #378 on: Fri, 25 July 2014, 11:37:17 »
Lucky DUCK!!!
Offline FrostyToast
  • Litshoard
Re: Post your rig
« Reply #379 on: Fri, 25 July 2014, 11:40:07 »
4670k @ 4.0Ghz
8GB of RAM
GTX 780
Looks like someone is a Noctua....
(•_•)
( •_•)>⌐■-■
(⌐■_■)
Fan.
YEEEEEEEEEEEAAAAAAAAAAAAAAAAAHHHHHHHHHHHHHHHHHHHHHHHH!
Quote from: elton5354
Re: Post your rig
« Reply #380 on: Fri, 25 July 2014, 11:45:40 »
3570k @ 4.6ghz
8gb ram
Ugh. I just CANNOT STAND red computers.
Offline cmadrid
Re: Post your rig
« Reply #381 on: Fri, 25 July 2014, 13:44:31 »
Fortunately you can get replacement parts to any piece of a caselabs case.. if it was yours! :p
Offline Frenir
  • HHKB Viking
Re: Post your rig
« Reply #382 on: Fri, 25 July 2014, 13:59:56 »
4670k @ 4.0Ghz
8GB of RAM
GTX 780
And some people dislike the noctua color scheme, holy moly that is a sweet looking rig.
Re: Post your rig
« Reply #383 on: Sat, 26 July 2014, 04:10:43 »
3570k @ 4.6ghz
8gb ram
What if they are running Windows 98?
First edition??
Offline melt
    • check out my Instagram!
Re: Post your rig
« Reply #384 on: Sat, 26 July 2014, 10:29:15 »
My on the go writers rig..
COFFEE SHOP SLAYER 3000
« Last Edit: Sat, 26 July 2014, 11:18:44 by melt »
Offline davkol
  •  Post Editing Timeout
Re: Post your rig
« Reply #385 on: Sat, 26 July 2014, 11:07:20 »
Cable covers a part of the LCD! The horror!
Offline melt
Re: Post your rig
« Reply #386 on: Sat, 26 July 2014, 11:13:45 »
Since that pic I got a right angle adapter... Helps tuck that coil away nicely!
Offline runcom
  • Topre lover
Re: Post your rig
« Reply #387 on: Sat, 26 July 2014, 12:31:13 »
3570k @ 4.6ghz
8gb ram
What is the case name? It's pretty cool :)
Don't be a dumbass, always be kind to people, here and afk
Offline SaySo
Re: Post your rig
« Reply #388 on: Sat, 26 July 2014, 13:37:37 »
« Last Edit: Tue, 03 July 2018, 12:44:36 by SaySo »
Offline Lain1911
  • God of the Wired
Re: Post your rig
« Reply #389 on: Sat, 26 July 2014, 14:04:26 »
I need to learn cable management T-T
Offline brand
Re: Post your rig
« Reply #390 on: Sat, 26 July 2014, 21:12:28 »
Muh rig
Poker II W/Blues
Offline Grim Fandango
Re: Post your rig
« Reply #391 on: Sat, 26 July 2014, 21:24:40 »
4670k @ 4.0Ghz
8GB of RAM
GTX 780
My cable management just looks like complete f#$^& **** compared to this.
Offline Roibhilin
  • Saver of Humens
Re: Post your rig
« Reply #392 on: Sat, 26 July 2014, 22:32:46 »
This thread is making me feel insecure about my FX-6300 and R9 270X
QFR | Poker II | Quickfire TK
Offline Smasher816
  • HHKB Master
Re: Post your rig
« Reply #393 on: Sat, 26 July 2014, 22:47:16 »
Muh rig
I like it. You don't see very many cases with white internals. I have to say, after picking up my HHKB I have really started to appreciate white hardware. It looks classy :thumb:
Offline mkawa
  •  No Marketplace Access
  • (ツ)@@@. crankypants
Re: Post your rig
« Reply #394 on: Thu, 28 August 2014, 12:03:47 »
i have a couple works in progress right now. i put most of this thing together last night (still in test-fit mode). the hadron OE power supply is really nice small custom unit, but silverstone just came out with their 600W SFX gold supply, that would fit in the upper right corner. still debating power on this one.
75828-0
75826-1
the idea was to make something small enough to put in a duffel and in carry-on luggage.
i'm also working on this H440 machine for skcheng:
75832-2
« Last Edit: Thu, 28 August 2014, 12:06:17 by mkawa »
Offline The Mad Professor
  • Ex Scientia, Rabies
Re: Post your rig
« Reply #395 on: Thu, 28 August 2014, 12:33:45 »
No pics, but here's my current rig:
i7-4770K
Corsair H80i
ASUS Maximus VI Extreme
2x GTX 760 Superclocked
32GB Corsair Dominator Platinum DDR3-1866
2x Samsung 840 Pro 256GB
2x Seagate Barracuda 1TB
2x Seagate Barracuda 3TB
Windows 7 Pro
Corsair AX860i
Silverstone Raven RV03
Upcoming Rigs:
Name: Olympus Mk II (replacement for Olympus)
i7-4930K
Corsair H110
ASUS Rampage IV Black Edition
2x GTX 760 Superclocked (upgrade later to dual 780 Ti)
64GB Corsair Dominator Platinum DDR3-2133
6x Samsung 840 Pro 256GB (more SSDs to be added later...)
Windows 7 Pro
Corsair AX860i (to be upgraded if needed)
Corsair Carbide Air 540 case (modded)
Name: Mouseion at Alexandria (Home Server)
Pentium G3220
ASRock Z87 Extreme 4
32GB Crucial Ballistix Sport DDR3-1600
9x WD Red 3TB
3x Seagate Barracuda 3TB
2x WD Red 1TB
1x WD Caviar Blue 1TB
1x Seagate Barracuda 1TB
FreeNAS
Corsair HX750
2x NZXT Source 210 cases modded together to make a double-wide case
i7-4790K
Corsair H80i
ASUS Z97 Pro WiFi
GTX 760 Superclocked (to be upgraded later to a 780 Ti, if necessary)
16GB Corsair Dominator Platinum DDR3-1866
2x Crucial MX100 512GB
2x WD Scorpio Black 750GB 2.5" drive
2x WD Red 1TB 2.5" drive
Windows 7 Pro
Silverstone SX600-G PSU
ASUS PB278Q 27" 1440p monitor
Case? Well that'll be custom.
« Last Edit: Thu, 28 August 2014, 12:46:19 by The Mad Professor »
Mad Science means never stopping to ask "What's the worst that could happen?" - Schlock Mercenary
Offline baldgye
  • Will Smith Disciple
Re: Post your rig
« Reply #396 on: Thu, 28 August 2014, 12:36:00 »
No pics, but
...but this is the media section?
Re: Post your rig
« Reply #397 on: Thu, 28 August 2014, 12:41:23 »
No pics, but
---- but it said post a rig.
Fine, I'll see what I can come up with as an alternative.
EDIT:
There... are ya happy?"  :))
« Last Edit: Thu, 28 August 2014, 12:47:50 by The Mad Professor »
Offline mkawa
Re: Post your rig
« Reply #398 on: Fri, 29 August 2014, 09:20:28 »
what do you think about the sx600? i'm thinking of replacing the bottom mount hadron 1u psu with that unit mounted where the drive bay used to be
Offline skcheng
    • Tenafly Dentistry
Re: Post your rig
« Reply #399 on: Fri, 29 August 2014, 09:29:02 »
Wooo Hooo!!   AKA my mkawa "budget build"  LOLOL!!
Hope my 15 yr. old gamer son likes his new computer   ;D ;D
