Author Topic: Is there somewhere a TKL keyboard (Filco form) with PCB mounted switches?  (Read 2214 times)
Offline G.C.W.
  • Formerly t!ng
Just wondering. I don't know a single one. All TKL's are plate mounted, or not?
Premium pouches for premium peripherals at www.wegner.design
Offline IvanIvanovich
  • Mr. Silk Underwear
Re: Is there somewhere a TKL keyboard (Filco form) with PCB mounted switches?
« Reply #1 on: Fri, 05 October 2012, 15:05:03 »
Only one that comes to mind is Neo Zelia.
Offline WhiteFireDragon
    • youtube
« Reply #2 on: Fri, 05 October 2012, 15:31:23 »
You don't see many PCB mounted boards in TKL form is because the PCB is large enough to show a decent amount of flex if there not standoffs everywhere. If you really don't like the plate, you can desolder all the switches and take off the plate.
Offline davkol
  •  Post Editing Timeout
« Reply #3 on: Fri, 05 October 2012, 17:29:11 »
Lorem ipsum dolor sit amet, consectetur adipiscing elit, sed do eiusmod tempor incididunt ut labore et dolore magna aliqua. Ut enim ad minim veniam, quis nostrud exercitation ullamco laboris nisi ut aliquip ex ea commodo consequat. Duis aute irure dolor in reprehenderit in voluptate velit esse cillum dolore eu fugiat nulla pariatur. Excepteur sint occaecat cupidatat non proident, sunt in culpa qui officia deserunt mollit anim id est laborum
« Last Edit: Mon, 10 December 2018, 15:15:12 by davkol »
Offline digitalleftovers
« Reply #4 on: Fri, 05 October 2012, 17:53:33 »
I thought I saw something about a new fullsize that didn't have a plate, but I think it was a plastic plate instead of metal.  You will find PCB mounted switches in the Pokers and KBT Pure.  For larger form factors they are most often found in Cherry (and other OEM's) SPOS boards.  The nice SPOS boards, however, are usually reinforced with a metal slab on the bottom.  So, not plate mounted, but still a substantial board.
Keyboards:
Filco 104 MX Brown (Otaku) - FKBN104M/NPEK 黒い空
Ducky TKL MX Brown/Blue 80% (White) - 1087-F 白の空
KBC Poker MX Red with PBT Key Caps - PFCN6000
"Consumers use touch screens.  Producers use keyboards."
