Author Topic: will a leopold space bar fit on a QFR?  (Read 3356 times)
Offline w4rtortle
  • QFR Black Switches
« on: Sat, 06 October 2012, 01:25:48 »
just as question states, Im assuming it doesnt?
Offline jwaz
  • * based mod
  • #geekhack on freenode
« Reply #1 on: Sat, 06 October 2012, 01:26:51 »
nope
Offline TheProfosist
  • Custom Layouts Only!
Re: will a leopold space bar fit on a QFR?
« Reply #2 on: Sat, 06 October 2012, 01:31:35 »
Nope but you could mod it with some epoxy.
Offline w4rtortle
« Reply #3 on: Sat, 06 October 2012, 01:32:52 »
rightio, thanks :)
Offline Dabboo
« Reply #4 on: Sat, 06 October 2012, 20:52:42 »
Along the same lines of thought: Can anyone suggest where to buy a plain black spacebar for the QFR?
I'm typing from a CM Quickfire with MX Blues.I'm also on a constant search for cool keycaps.
PM me if you've got any you'd like to send to Australia, I'm happy to buy!
Offline alaricljs
  • I be WOT'ing all day...
« Reply #5 on: Sat, 06 October 2012, 20:55:22 »
WASDkeyboards.com
Filco w/ Imsto thick PBT
Offline Human
« Reply #7 on: Mon, 08 October 2012, 14:54:29 »
To prevent misunderstanding here, the answer to TS is "Yes&No".
FC500R is using spacebar of its own kind, while FC200R using a more compatible spacebar.
The one in elitekeyboard is for FC200R, which probably can be fitted onto Filco/CM QFR.
