Author Topic: Is it just me? Cloud of boobs related.  (Read 9157 times)
Offline Xerobasix
« on: Sat, 06 October 2012, 22:22:55 »
My reds have a slight friction to them, like very fine grains of sand in the switch that I can feel when I slowly depress it.  Anyone else have a similar issue/paranoia?
CM Quickfire Rapid - Brown | Blue | Red
Re: Is it just me? Cloud of boobs related.
« Reply #1 on: Sat, 06 October 2012, 22:27:26 »
When I tried reds on someone else's board, yes, a little bit. But no problem with blacks
Offline tjcaustin
  • King Klaxon
    • Buy stuff
« Reply #2 on: Sat, 06 October 2012, 22:36:54 »
I don't have anything to add, but I was promised a cloud of boobs.
Offline Xerobasix
« Reply #3 on: Sat, 06 October 2012, 22:39:57 »
To be fair, you were promised a subject related to a cloud of boobs.  I'd oblige you further with a picture, but I'm sure that goes against some forum rule :P
Offline lazerpointer
  • ya gotta stay phresh
« Reply #4 on: Sat, 06 October 2012, 22:42:51 »
To me the reds are great for gaming. I'm starting to get used to the browns for typing, as I seem to make less errors on typeracer with them.
About the grittiness... That's the plastic rubbing on plastic. Not much can be done there.
i type, therefore i geekhack
Offline tjcaustin
  • King Klaxon
    • Buy stuff
« Reply #5 on: Sat, 06 October 2012, 22:45:50 »
And so you fulfilled (I only found the cloud of boobs reference after I posted (of course).
Or would it:
Offline modulor
« Reply #6 on: Sat, 06 October 2012, 22:49:35 »
Never felt grittiness on any of my reds or ghetto reds or blacks but the right lubrication makes a world of difference.  You should check out this thread:  http://geekhack.org/index.php?topic=34332.0
Reds + Lube = Silky Smoove
NP-R (soon) | 21XX | Leggera-G Acrylic | Classic TKL | Frog TKL 8K | GH60revC | R1 86U 45g | G80-2100HDU | G80-3000HAU | G80-3700HAU | QFR V1 | FC200R | Poker X | G80-11900LUMEU
Offline Xerobasix
« Reply #7 on: Sat, 06 October 2012, 23:15:08 »
Yeah, I gamed all day on blues then went to reds... fingers thanked me.  It's been a lazy Saturday :D
I might have to do that... I'm not sure how effective lube will be without taking apart all the switches.  I guess there's another project in my future. :(
edit: @ tj ... I did the clouds.  Just need some censorship black bars and it would look completely legit :D
Offline Lethal Squirrel
  • I <3 60%
« Reply #8 on: Sat, 06 October 2012, 23:24:10 »
The grittiness goes away
Offline WRXChris
« Reply #9 on: Sat, 06 October 2012, 23:28:02 »
I have 2 boards with reds and one is scratchier than the other.  The poker is scratchy while my filco is smoother.  I'm not sure if this is due to pcb vs. Plate mount or different batches of switches getting different quantities of factory lube, or even wear (I've had the poker longer than the filco). I'm guessing its a combo of these factors, but one thing I know for sure is that lubing them with krytox eliminates the annoying scratchiness!
  • I <3 60%
« Reply #10 on: Sat, 06 October 2012, 23:31:49 »
I never understood the idea that the surface that a switch is mounted on, can change the grittiness of a key stroke. How can being mounted on a plate affect the internals of the switch? : /
« Last Edit: Sat, 06 October 2012, 23:34:46 by Lethal Squirrel »
« Reply #11 on: Sat, 06 October 2012, 23:34:55 »
I thought the more used they are the less scratchy they'd be? Lube definitely helps though.
  • I <3 60%
« Reply #12 on: Sat, 06 October 2012, 23:35:06 »
I never understood the idea that the surface a switch is mounted on can change the grittiness of a key stroke. How can being mounted on a plate affect the internals of the switch? : /
Offline WRXChris
« Reply #13 on: Sat, 06 October 2012, 23:38:59 »
Maybe you're right; my poker with blues was VERY scratchy when I first got it, and it smoothed out quite a bit.  Still scratchy though and the gpl-103 I have is too viscous for blues and reduces the click, I need some thinner gpl-100 for that board.
Offline WRXChris
« Reply #14 on: Sat, 06 October 2012, 23:42:52 »
its a leverage issue.  Pcb mounted switches are supported at a lower point of the switch which allows them to flex from side-to-side when you don't press them perfectly perpendicularly, which increases the friction between the stem and housing.
« Last Edit: Sat, 06 October 2012, 23:44:29 by WRXChris »
  • I <3 60%
« Reply #15 on: Sun, 07 October 2012, 00:02:44 »
I was actually thinking that same thing as I was typing that out. makes total sense.
Offline MMB
« Reply #16 on: Sun, 07 October 2012, 00:14:13 »
Wrong.
« Reply #17 on: Sun, 07 October 2012, 01:55:08 »
Holy crap, all that for a keyboard? Nothing could posess me to take apart my Ducky switch by switch just to add lube.... it types great already lol.
« Reply #18 on: Sun, 07 October 2012, 12:12:11 »
^ You have no idea of how much greater it can be.
Offline Xerobasix
« Reply #19 on: Sun, 07 October 2012, 13:16:44 »
I watched the video that was posted in MM's thread... but it was for PCB mounted switches.  Is it possible to do something similar with plate mount, or do they have to be desoldered to lube?
« Reply #20 on: Sun, 07 October 2012, 13:25:51 »
You have to desolder in most cases.
Offline MMB
« Reply #21 on: Sun, 07 October 2012, 13:31:26 »
You only say that because you haven't tried a lubed switch :)
It's a world of difference.
For PCB mounted switches, unless you have a phantom pcb/plate, you will need to first desolder the switches from the PCB to disassemble the switch housing.
Offline Xerobasix
« Reply #22 on: Sun, 07 October 2012, 13:48:03 »
This is turning into quite the project indeed.  I think I need to buy a practice board... (it's really quite easy to justify buying more keyboards isn't it?)
Offline hashbaz
  • Grand Ancient One
  • * Moderator Emeritus
Re: Re: Is it just me? Cloud of boobs related.
« Reply #23 on: Sun, 07 October 2012, 14:08:29 »
You must be new here.
« Reply #24 on: Mon, 08 October 2012, 00:09:06 »
Guilty as charged. I admit, I've spent a good deal of money on these things as well though heheh
Offline TheQsanity
  • SmallFry Lovin'
« Reply #25 on: Mon, 08 October 2012, 00:21:19 »
http://www.caig.com/
Best lube ever... I use it for everything...
F5 and D5 are great for cleaning.
SmallFry! <3
Offline TheProfosist
  • Custom Layouts Only!
« Reply #26 on: Mon, 08 October 2012, 00:24:53 »
wow were you around when i was doing lubing before gh went down as thats the same products i use at least when i want to lube without openning the. Switch which does help some but not nearly as much.
Offline TheQsanity
  • SmallFry Lovin'
Re: Re: Re: Is it just me? Cloud of boobs related.
« Reply #27 on: Mon, 08 October 2012, 01:14:23 »
I use White lithium grease.
Faders seem to be a bit less messy, but do they work as well?
Yes I was haha, Just got back into the keyboarding thing lol.
gotcha well i can help u out in reguars to those lubes just use their fader greese on my spacebars stabilizers today.
« Last Edit: Mon, 08 October 2012, 23:23:44 by reaper »
SmallFry! <3
Re: Re: Re: Re: Is it just me? Cloud of boobs related.
« Reply #28 on: Mon, 08 October 2012, 01:20:31 »
wow my bad that was supposed to say:
Well i can help you out in reguards to those lubes. I just used their fader greese on my spacebar stabilizer today.
« Last Edit: Mon, 08 October 2012, 23:23:58 by reaper »
Offline WRXChris
« Reply #29 on: Wed, 10 October 2012, 13:58:13 »
After putting stickers on my poker, I no longer think the excess flex on a pcb-mount board is coming from the mount.  Stickered PCB-mount switches feel very much like plate mounted switches, if not a bit more stable (though the bottom out still feels different of course).  I am now convinced that the instability of pcb-mount switches is primarily due to the play between the top and bottom sections of the switch housing.  A plate hugs the switch at the point where the top and bottom of the switch housing come together, adding stability to this weak point.
Offline bisl
« Reply #30 on: Wed, 10 October 2012, 14:37:26 »
After reading this thread, I'm curious about trying to lube up the reds on my filco MJ2 TKL. However, having never really taken apart a keyboard to this degree, I'm curious--is there a quick way to identify whether desoldering is required just by looking at a board? Or do you have to know the construction of each individual board and remember whether they're PCB or plate mounted?
I'm trying to get one of bpiphany's programmable PCBs so there's some desoldering in my future anyway (and indeed this is probably the answer to my question in this particular case) but if there's a way to lube up my switches before I desolder everything to replace the PCB that would be nice.
Offline alaricljs
  • I be WOT'ing all day...
« Reply #31 on: Wed, 10 October 2012, 15:06:21 »
Shine a light, look for PCB under the caps... or pull a cap and look.
Filco's are all plate and require desoldering.
Filco w/ Imsto thick PBT
« Reply #32 on: Wed, 10 October 2012, 15:11:41 »
You can tell by just looking at it. Plate mounted boards have a metallic plate (which is a given) between the switches and the PCB. You can see it by taking off a key cap.
Offline bisl
« Reply #33 on: Wed, 10 October 2012, 15:20:23 »
Ah, so if it wasn't plate mounted, when I take off a cap I'd just be looking at the PCB itself? This is good to know. Next step is figuring out the disassembly!
Offline TheQsanity
  • SmallFry Lovin'
« Reply #34 on: Wed, 10 October 2012, 18:56:01 »
Unless you are looking for a project, you could just squirt some in the crack :D
SmallFry! <3
« Reply #35 on: Wed, 10 October 2012, 19:10:12 »
yep this is what I did initially as well.
