Author Topic: CM Storm Trigger (10key, browns, backlighted) is $80 AR at Amazon  (Read 2003 times)
Offline Chocobo
http://www.amazon.com/CM-Storm-Trigger-Mechanical-SGK-6000-GKCM1-US/dp/B007TFOO6K
You have to choose Amazon from the "more buying choices" list on the right.  There's a $10 rebate here: http://g-ecx.images-amazon.com/images/G/01/00/00/26/91/19/26/2691192690._V386980879_.pdf
Thinking about buying this one but I'm not sure... I haven't seen anyone discuss this board much since it came out in late 2011.
I'm somewhat of a mechanical keyboard noob... I remember reading about how the CM Storm Quickfire Rapid was made by the same company that makes really good quality keyboards, but the Quickfire Pro (with 10key) was made by a lower quality manufacturer. What's the case with the Storm Trigger, does anyone know?
Offline alaricljs
  • I be WOT'ing all day...
Re: CM Storm Trigger (10key, browns, backlighted) is $80 AR at Amazon
« Reply #1 on: Wed, 10 October 2012, 08:37:44 »
Carter is a CM rep that pops over here when he has some free time...
As for your question.  I'd recommend getting CM Storm QuickFire rapid with MX Red, since it's made by Costar.  While CM Storm Trigger and CM Strom QuickFire Pro are made by iOne.
Costar manufactures Filco, WASD Keyboards, Das Keyboards, ThermalTake Mekka G1... etc
iOne manufactures Razer Blackwidow, iOne, Max Keyboards, QPad, XAmor... etc
In short Costar > iOne build quality.
First of all, Trigger is made by Costar.
Second of all, both Reds and Blues are on the way but will be about 1.5-2 months before they hit the channels.
So the Trigger is made by Costar same as the QFR.
Filco w/ Imsto thick PBT
Offline shadewolf
  • ಠ_ಠ
« Reply #2 on: Wed, 10 October 2012, 09:40:33 »
Also note that it shows as shipping in 1-2 months when Amazon is selected.
Offline nullstring
« Reply #3 on: Mon, 22 October 2012, 19:43:01 »
Wish I would've noticed this before.
Shows out of stock now.
I think I will probably wait for blackfriday and hope something shows up then.
