Author Topic: Turns out my KBC Poker's DIP Switches are backwards...  (Read 2983 times)
Offline Mainian
« on: Sat, 13 October 2012, 13:41:54 »
http://webwit.nl/input/misc/poker/usermanual.pdf
Was wondering why my settings were never working as intended... lol...
Offline IvanIvanovich
  • Mr. Silk Underwear
Re: Turns out my KBC Poker's DIP Switches are backwards...
« Reply #1 on: Sat, 13 October 2012, 13:52:21 »
It's all Pokers, not just yours. The manual is incorrect.
Offline Mainian
« Reply #2 on: Sat, 13 October 2012, 14:09:16 »
LOL... wish I had known that... I have been wondering why I could never get the caps and control to switch place T_T. (I'll be quite honest... I never tried that hard since it was just my "for work" board)
Offline TheQsanity
  • SmallFry Lovin'
« Reply #3 on: Sat, 13 October 2012, 14:23:08 »
Would anyone put an mx Lock on an "fn" key? From what I heard the fn+spacebar only locks the arrow keys on the bottom right?
SmallFry! <3
Offline Glissant
« Reply #4 on: Sat, 13 October 2012, 14:47:47 »
My KBC Poker manual (paper) is exactly right. Is the pdf manual incorrectly made by a user maybe?
« Reply #5 on: Sat, 13 October 2012, 15:01:57 »
I was talking about the paper that came with the keyboard. The numbers on the section for dipswich are reversed, 1 should be 4, and so on. I got mine on release, maybe they corrected it later on?
Offline Glissant
« Reply #6 on: Sat, 13 October 2012, 15:03:22 »
That must be it then. They corrected it in a later production run =).
