Author Topic: HHKB2 Keycaps anyone?  (Read 3201 times)
Offline Carefoot
    • http://carefoot.ca
« on: Tue, 16 October 2012, 05:15:30 »
Looking for some HHKB2 keycaps, specifically any kind but if theres a choice.
I would be looking for ones with both English and Korean (hangul), and white.  If not white than chrome.  If not chrome than black.  If not printed keys than non-printed.
ETC!
Down the line.
Cheers and thanks.
* - Black "Otaku" HHKB Professional 2
* - Filco Neo Multifinger Touch Pad
* - AKG701 headphones
* - Steelseries [Rubberized/Raw] Sensei
Offline Cynez
Re: HHKB2 Keycaps anyone?
« Reply #1 on: Tue, 16 October 2012, 13:48:09 »
ETC!
Down the line.
Cheers and thanks.
Are you looking to buy them from someone or a site?  If you just need a site check here: http://elitekeyboards.com/products.php?sub=access,toprekeys
If you want other colors than the set just made for the HHKB, the realforce ones will fit as well.  It just may require finding the right key in the set, so I would recommend using the blank keys.  Bought a blank red set a while back of the realforce keys and found enough keys in the set to fit my board.
KBT Race w/ Reds | HHKB Pro 2 | KBC Poker w/ Reds | IBM Model M '93 | Noppoo Mini w/ Reds | Filco Majestouch 2 w/ Browns
Offline naisanza
« Reply #2 on: Tue, 16 October 2012, 16:17:29 »
ETC!
Down the line.
Cheers and thanks.
Scroll down near the bottom for HHKB keycaps.
http://elitekeyboards.com/products.php?sub=all
| HHKB2ProOtaku | KBCPokerOtaku(MXblue) | KBTPureOrangeBrown | Heatware
