Author Topic: My dampened key sticks D: [RESOLVED]  (Read 2719 times)
Offline NikoGasm
  • Platinum mad.
« on: Tue, 16 October 2012, 18:03:00 »
So I just put some o-rings on my Key Cool 87 and the backspace doesn't seem to want to come back up anymore. Anyone have a solution to the problem? It's not the switch itself, I tested that.
Edit: Nevermind, messed around with it for a bit and I figured it out.
« Last Edit: Tue, 16 October 2012, 18:13:00 by NikoGasm »
Re: My dampened key sticks D:
« Reply #1 on: Tue, 16 October 2012, 18:05:11 »
Are you sure that the ring is seated properly, all the way down?
Next, is it installed properly on the stem?
You could always just leave the ring off that one key ......
- D Trump 2026-10-24
Offline Moth
  • Acherontia atropos
Re: My dampened key sticks D: [RESOLVED]
« Reply #2 on: Tue, 16 October 2012, 21:43:14 »
So, what was the problem?
Offline NikoGasm
  • Platinum mad.
« Reply #3 on: Tue, 16 October 2012, 21:54:26 »
The two things that go into the key that the stabilizer bar goes into weren't facing the proper direction. I just flipped them around and it worked perfectly.
« Reply #4 on: Tue, 16 October 2012, 21:57:39 »
^ hahaha nice :P
