Author Topic: Ay yall, this thing be clicky?  (Read 2467 times)
Offline Capitalistix
  • Cherry MX Green Disciple
    • Uncanny Electronics
« on: Tue, 16 October 2012, 20:06:24 »
Offline dreamingftw
Re: Ay yall, this thing be clicky?
« Reply #1 on: Tue, 16 October 2012, 20:09:41 »
I don't think this is. There was someone else in this forum, forget who, that bought one and turned out to be rubberdome. He was also upset because he couldn't get a refund.
Offline tjcaustin
  • King Klaxon
    • Buy stuff
« Reply #2 on: Tue, 16 October 2012, 20:13:04 »
Yeah, same seller and all.  It's a rubber dome thing that "clicks"
« Reply #3 on: Wed, 17 October 2012, 01:28:03 »
Aww sneaky sneaky Mr. eBay seller! Thanks guys =]
« Reply #4 on: Wed, 17 October 2012, 03:34:56 »
Any good suggestions as to a mechanical tenkeypad?
Offline WhiteFireDragon
    • youtube
« Reply #5 on: Wed, 17 October 2012, 05:41:09 »
That ebay seller is a *****. He knows full well by now about the "clicky" deception, but continues to list it as that. If you buy the item and dispute it afterwards, you'll lose because ebay will rule "clicky" as a subjective matter. It happened to the last guy.
« Reply #6 on: Wed, 17 October 2012, 09:24:54 »
I think there was a Buckling Spring one that came with the M15, but they're... expensive.
Your bestbet is probably to get a kinesis or goldtouch one from eBay. They use Cherry MX Keyswitches.
Offline lazerpointer
  • ya gotta stay phresh
« Reply #7 on: Wed, 17 October 2012, 12:40:02 »
Obviously someone likes ergonomic keyboards ;)
I suggest the cm storm line. If you want a plainer looking board go with Ducky!
I mis-read. Yes those are good keypads ;D
« Last Edit: Wed, 17 October 2012, 12:49:30 by Flip »
i type, therefore i geekhack
Offline hashbaz
  • Grand Ancient One
  • * Moderator Emeritus
« Reply #8 on: Wed, 17 October 2012, 12:45:02 »
Goldtouch numpads with MX browns come up frequently on ebay for $20-$30.
Offline IvanIvanovich
  • Mr. Silk Underwear
« Reply #9 on: Wed, 17 October 2012, 13:18:01 »
Sometimes goldtouch are even cheaper. They usually have browns, but sometimes blacks. But for such a low price maybe you won't be too picky.
