Author Topic: Re: Fit of WASD Keycaps  (Read 4933 times)
Offline R54
« on: Thu, 18 October 2012, 00:23:33 »
Today I got some new keycaps for my das keyboard. Upon removing the keycaps from the Das and comparing the force needed to remove the replacements from WASD, it seems like the WASD ones have a tighter fit on the switches. Which brings me to my question.
Does the additional force needed to both remove as well as properly seat the WASD keycaps on the swtiches pose a potential issue for long term switch reliability, or does the construction of the das keyboard (namely the plate) help prevent this.
Thanks much for your help!
Offline R54
« Reply #1 on: Thu, 18 October 2012, 00:41:28 »
Also, here are some pictures of the new keycaps :D Not sure about them since I haven't had any non-stock stuff on here, but I think I'm liking it
Re: Re: Fit of WASD Keycaps
« Reply #2 on: Thu, 18 October 2012, 01:00:14 »
On - no.  Once the switch bottoms out it bottoms out.  Pressing it harder won't make much difference (unless you use a hammer.
Off - could do.  It is possible to rip the stem out of the switch if you pull too hard, if the key cap is too tight as fit on the stem.  Just be careful when removing them.
Offline R54
« Reply #3 on: Thu, 18 October 2012, 01:09:59 »
I see. So is there any "half-way" failure where you partially rip the stem out? Either way, I'll be more careful removing them.
« Reply #4 on: Thu, 18 October 2012, 04:15:57 »
I suppose you could partially dislodge the top of the switch, but that would weaken the switch structure and lead to failure sooner rather than later.
You should always take care when removing key caps - try to wriggle the key cap off rather than just jerking it upwards.  And I try to steady the cap so it comes straight up (in case the key cap puller slips off one side, for example).
Offline akuJIWA
  • Lock 'N Load!
« Reply #5 on: Thu, 18 October 2012, 05:37:08 »
ahhh.. dat das. such a beautiful keyboard.
The Cheat - B/R/B ; Clear switch with 62g springs
quit
Offline ranviper
  • Nerd.
« Reply #6 on: Thu, 18 October 2012, 13:03:12 »
Dude that das is hot. Wow. lol.
ENVY!
EC66 | MIYA
Offline R54
« Reply #7 on: Thu, 18 October 2012, 15:05:58 »
ENVY!
Do you think it looks better post keycaps? Still undecided personally but it's growing on me.
Cheers!!
Offline clickclack
  • Board Chow EXTRAORDINAIRE
« Reply #8 on: Thu, 18 October 2012, 20:28:33 »
... it seems like the WASD ones have a tighter fit on the switches...
Hi R54,
WASD keys are made by the same tooling Filco uses and they are usually very tight fitting. Does this pose a potential problem to the switch when removal is difficult? YES, it does, however, if you are cautious you should generally be fine. In fairness though I should mention that you can pull the switch stem out of the housing by accident if it's to tight. If the switch cannot easily be reasembled afterwards or pressed back in or if the contacts are bent terribly then it will likely not work. The bigger problem is the potential for the pcb contacts to weaken or trace damage to occur with excessive and forcefully handling. This can happen with or without the addition of a plate.
If it's tight, then use a firm but gentle rocking/wiggle when pulling up.
...geee that sounded dirty!  =D
-cc  OUT!
862+ keyboards and counting!   R.I.P.ster          Vendor link ->Clack Factory
Offline suprsmo
  • Sydney, Australia
« Reply #9 on: Thu, 18 October 2012, 20:55:37 »
Poker
QFR
Offline R54
« Reply #10 on: Sat, 20 October 2012, 23:09:27 »
Hi R54,
-cc  OUT!
Thanks!! I honestly didn't think I'd you reply to a beginning keyboard enthusiast's queries, but I appreciate the help!
I ended up taking off the RGB modifiers that I had on there, and I think it gives it a more clean look.
Cheers!
R54
« Reply #11 on: Sun, 21 October 2012, 05:31:57 »
I think key cap fit is a subject close to CC's heart ;)
Offline Goliath
  • Platinum mad.
    • YouTube
« Reply #12 on: Mon, 22 October 2012, 23:56:00 »
I got a space bar from WASD Keyboards and it does fit a little tighter than any of my other keys. It has not caused me any issues. You should be all good!  ;D
CM Storm Quickfire Rapid (lubed)
