Author Topic: How to clean scarface caps  (Read 9311 times)
Offline longweight
  • philanthropist
« on: Thu, 18 October 2012, 16:35:04 »
Hi all,
So one of the WASD sets seems to be dirty mainly due to skin grease, I always wash my hands before touching these caps so I can't think of anything else that could have caused it.
My question is, what do I do to clean them? They seem to be untreated cast aluminium, any recommendations?
Here is a picture of a dirty key next to a clean key:
Offline SmallFry
Re: How to clean scarface caps
« Reply #1 on: Thu, 18 October 2012, 16:54:37 »
Erm, mineral spirits or similar?
Offline longweight
  • philanthropist
« Reply #2 on: Thu, 18 October 2012, 16:55:38 »
Can you please link me to something? I will try and pick something up tomorrow.
Offline Batmann
« Reply #3 on: Thu, 18 October 2012, 17:01:59 »
hey longweight,
these scarface are awesome, did you get them in a group buy?
Offline longweight
  • philanthropist
« Reply #4 on: Thu, 18 October 2012, 17:11:16 »
Hey,
Thank you :) No I spent 6 months looking for them and found someone willing to sell me a set! I have only seen 3 other sets outside of KBDmania.
Offline Batmann
« Reply #5 on: Thu, 18 October 2012, 17:25:25 »
was expecting something like this!
Well then enjoy it ^^
Offline longweight
  • philanthropist
« Reply #6 on: Thu, 18 October 2012, 17:26:31 »
Haha yeah they were hard to find but I love them more than any other keyboard thing! They are the only reason that I still have an MX board.
Offline DanGWanG
  • Higher Standards
    • DanGWanG's Keyboard Blog
« Reply #7 on: Thu, 18 October 2012, 17:50:35 »
Couldnt you just use dental tabs?  Theyre safe on metal
Offline longweight
  • philanthropist
« Reply #8 on: Thu, 18 October 2012, 17:51:14 »
Maybe...! What are dental tabs?
Offline DanGWanG
  • Higher Standards
« Reply #9 on: Thu, 18 October 2012, 17:53:23 »
Tablets that you add water to for cleaning dentures.  I use them all the time to clean my keycaps.
Offline longweight
  • philanthropist
« Reply #10 on: Thu, 18 October 2012, 17:54:43 »
Ahhhh ok that makes sense :) I will pick some up tomorrow, I also have vinegar to try and I have been recommended this: http://www.quickleen.co.uk/quickleen_aluminium_cleaner.htm on another forum so that will be the last resort!
Offline SmallFry
« Reply #11 on: Thu, 18 October 2012, 18:33:30 »
That QuickLeen looks abrasive, wouldn't use that myself...
Offline longweight
  • philanthropist
« Reply #12 on: Fri, 19 October 2012, 15:10:50 »
Looks ok to me, what makes you think that it is abrasive?
Offline SmallFry
« Reply #13 on: Fri, 19 October 2012, 17:11:55 »
Most metal cleaners are polish which means that they have abrasives in them.
Offline bounce
« Reply #14 on: Fri, 19 October 2012, 21:42:46 »
say, do u use cold or warm water for the cleaning process?
Offline SmallFry
« Reply #15 on: Fri, 19 October 2012, 21:43:50 »
Doesn't matter if you let it sit it'll just get cold anyways. :)
Offline jeroplane
« Reply #16 on: Sat, 20 October 2012, 02:44:58 »
The box says use warm water. I use the hottest water out of the tap. It's nowhere near boiling so it won't warp your caps. Warm water always seems to remove grime better than cold (anyone who's ever done the dishes will know this).
My signature hasn't changed since 2012. I should really update it.
Offline longweight
  • philanthropist
Re: Re: How to clean scarface caps
« Reply #17 on: Sat, 20 October 2012, 03:03:23 »
Yeah but this is designed for untreated aluminium.
Offline laffindude
« Reply #18 on: Sat, 20 October 2012, 04:13:51 »
Magic eraser. Yes it is an abrasive. I've use it to clean MBPs. The discoloration is probably oxidation so you need to use abrasives to clean it.
« Reply #19 on: Sat, 20 October 2012, 23:17:36 »
Keep in mind that even "untreated" Aluminium will still have a few microns of oxide on the outside, or anywhere in contact with the O2 in air.
Aluminium oxide, or Al2O3, is very hard. Anodyzing is all about making this layer thicker (as well as introducing colour impurities), for better hardness and scratch resistance. I love ceramics.
