Author Topic: Filco Majestouch-2 mx-brown  (Read 1803 times)
Offline gorebrush
« on: Sat, 20 October 2012, 13:47:18 »
Typing to you all on my new purchase. This baby set me back £120 of my Great British Pounds and it was worth every penny.
I'd love to try a keyboard with Cherry MX Blue's but fear they may be too loud for work (ultimately I want a second keyboard to take to work with me as there are only rubber domed junk ones at work)
I work shifts too so don't have a regular desk in order to leave a keyboard there.
Am tempted to get a Blue version of this keyboard and use that at home, but I am also more than happy to get another one of these keyboards as it is just devine!
Love it!
Re: Filco Majestouch-2 mx-brown
« Reply #1 on: Sat, 20 October 2012, 20:21:47 »
Glad you like your Filco! They are indeed great keyboards. Blues are pretty loud, so I'd probably leave it at home if you're in a work environment that's generally quiet.
« Reply #2 on: Sun, 21 October 2012, 04:26:00 »
Depending on your work environment, blues may indeed be too loud.  Mine (a Ducky Shine (version 1) with MX blues) is drowned out by the arguments, er, enthusiastic discussions, that occur down the rough end of the office, but in quieter moments it does seem like the keyboard is the loudest thing.  No-one has complained yet :)
If you will be taking the keyboard back and forth, TKL would be a good idea.  Apart from being smaller (and thus more likely to fit into a bag), it is also somewhat lighter.
And/or consider a special carrying case.  There are a couple of threads here, and I think one of the major vendors also sells cases.
Offline tcv
« Reply #3 on: Sun, 21 October 2012, 17:25:25 »
Had a blue tenkeyless and I currently use a DAS with browns at work.
I would not use a keyboard with blues at work. I think brown is the threshold of acceptable.
If you have your own office and aren't around others then maybe that could work though
Offline ValerieV
« Reply #4 on: Sun, 21 October 2012, 17:38:48 »
I use my cherry mx blue keyboard (DAS) at work and at first people thought i was nuts. It was clicky and it had no lettering. One day i called in sick and other people used my desk. They all loved the keyboard and said how they wished they had one like that (with the lettering). The Filco browns are nice though but i am torn between Filco browns and Leopold browns.  :-\
Offline anomaly
« Reply #5 on: Mon, 22 October 2012, 17:14:43 »
I have the original Majestouch mx browns. It's the keyboard I use the most. I love the sound they make when I bottom out (I love bottoming out). I prefer browns when typing and FPS gaming over blues. Great keyboard!
Filco Majestouch tenkeyless blues | Filco Majestouch browns | Unicomp buckling spring | Realforce 103UB 55g
