Author Topic: help me chose a keyboard  (Read 2264 times)
Offline wheelspk
« on: Mon, 22 October 2012, 09:19:37 »
hello,
look into buying a keyboard from ONLY EBAY.
should be:
mx red switch ONLY.
TENKEYLESS
back-lighting is not important but will not hurt.
keys should be easily replaceable .
thanks
  • Live long and prosper
tp thread is tp thread
Offline ih8
Re: help me chose a keyboard
« Reply #2 on: Mon, 22 October 2012, 09:27:42 »
CM quickfire rapid in reds would be your best bet as far as price for quality
« Reply #3 on: Mon, 22 October 2012, 09:29:43 »
That too.  Although not backlit.  But definitely the cheaper option, and probably the better option quality wise...
Offline wheelspk
« Reply #4 on: Mon, 22 October 2012, 09:37:07 »
i wish i could buy the cm storm red from eBay buy its not available on ebay..
Offline wheelspk
« Reply #5 on: Mon, 22 October 2012, 09:40:02 »
what abt this one..i know-its not from eBay buy whats your taught abt this one??
http://elitekeyboards.com/products.php?sub=leopold,tenkeyless&pid=fc200rrab
Offline jeroplane
« Reply #6 on: Mon, 22 October 2012, 09:43:37 »
You won't go wrong with that one. Leopolds are very well made. The only issue you'll run into is finding compatible spacebars if you ever want to change the keycaps. The stabilizer layout on the spacebar is different to most other boards.
My signature hasn't changed since 2012. I should really update it.
« Reply #7 on: Mon, 22 October 2012, 09:45:02 »
Looks like a good quality board.  Meets all of your criteria, minus the eBay part.
Just a question: why do you want to buy ONLY from eBay?
Offline wheelspk
« Reply #8 on: Mon, 22 October 2012, 09:55:23 »
o im not in usa so its easier for me to buy from ebay...and get it shipped.
Offline wheelspk
« Reply #9 on: Mon, 22 October 2012, 09:58:15 »
:( but i want to change the spacebar too...
what abt this one?
http://www.ebay.com/itm/Ducky-9087-Dragon-year-edition-LED-backlit-mechanical-keyboard-cherry-MX-Red-/300801131841?pt=PCA_Mice_Trackballs&hash=item4609250541
« Reply #12 on: Mon, 22 October 2012, 10:13:35 »
Yes, I would.  I'm sure others will agree...
