Author Topic: Model M13 Help  (Read 1673 times)
Offline Capitalistix
  • Cherry MX Green Disciple
    • Uncanny Electronics
Model M13 Help
« on: Mon, 22 October 2012, 18:24:23 »
I recently was able to acquire an M13 but ai can't seem to get the trackpoint/clitoriris mouse thing to function >.> Do these things normally just break or is there something I might need to install first (software wise?) If it is prone to bust is there a known way to fix it? (something to desolder/replace etc.?)
Offline SmallFry
Re: Model M13 Help
« Reply #1 on: Mon, 22 October 2012, 18:54:43 »
Can't get the clitoris to work? Have you tried licking it? What about using more than one finger? Haha!
Jokes aside, does your cable have a PS/2 connector for each the keyboard and the mouse?
Re: Model M13 Help
« Reply #2 on: Mon, 22 October 2012, 19:31:34 »
Damn, Ive even been rollin' my fist on it and I can't get no response! Though I dont wanna lick it, as I have no idea whose touched it :P Yeah my cable splits into two PS/2 plugs. I have them both plugged in and everything.
Offline 0100010
  • Not Sure
Re: Model M13 Help
« Reply #3 on: Mon, 22 October 2012, 19:48:49 »
Maybe build a PS2 pinout extension so you can check for signal on the data line when you move the clit?
Re: Model M13 Help
« Reply #4 on: Mon, 22 October 2012, 21:43:10 »
Started workin! Just had to restart! lol go figure
