Author Topic: What Cooler Master keyboard is this?  (Read 3335 times)
Offline ranunky
« on: Tue, 23 October 2012, 07:27:19 »
http://www.amazon.co.uk/gp/product/B0087DJUFS
The title says pro, the description says rapid black/brown/blue and the product code is for the rapid red - three totally separate products. I just bought it because I want a UK red.
Offline newtrekemotion
Re: What Cooler Master keyboard is this?
« Reply #1 on: Tue, 23 October 2012, 07:32:10 »
It is the pro. The QFR is a tenkeyless and that isn't.
In Mail: HHKB Pro 2
Current: Endura Pro
Past: Das Professional , KBT Race (White), CM QFR , Leopold TKL (Clear), Dell 101W (Black Alps)
Offline MissMurd3r84
  • In IRC wondering why Kmiller8 is yelling.
« Reply #2 on: Tue, 23 October 2012, 07:32:40 »
Picture looks like the pro, seems to be the same confusion on other sites, too. http://geekhack.org/index.php?topic=35734.0
KBC Poker - Red switches. Noppoo Choc Mini - Black switches. Leopold FC700R (White) - Blue switches. Ducky YOTD - Brown switches. Razer BW - Blue switches and rusted.
Offline ranunky
« Reply #3 on: Tue, 23 October 2012, 07:36:55 »
Maybe they have the wrong picture, it says it's the quickfire rapid in the description. And the title and product code are both for the rapid.
« Reply #4 on: Tue, 23 October 2012, 07:41:20 »
Yep I was too quick (edit: pun not intended). The picture is the pro, but the spec's are exactly the QFR. The listed weight is for the QFR. So I guess it becomes a question of which do you trust more the picture or the description? Either way, my experience with Amazon has always been good (when buying from them not a 3rd party) and you could probably return it based on it not matching either one..
In Mail: HHKB Pro 2
Current: Endura Pro
Offline ranunky
« Reply #5 on: Tue, 23 October 2012, 07:47:16 »
Aye, that's my plan ;-).
Offline vun
  • Just one more thing
« Reply #6 on: Tue, 23 October 2012, 07:50:36 »
The title says "Pro Fire Rapid", last time I checked they were called quickfire pro and quickfire rapid.
Huh...
« Reply #7 on: Tue, 23 October 2012, 07:52:31 »
Huh...
The listing is all sorts of messed up.
Let us know which one it is too.
In Mail: HHKB Pro 2
Current: Endura Pro
Offline ih8
« Reply #8 on: Tue, 23 October 2012, 10:55:56 »
definitely the pro
Offline fuzzybaffy
« Reply #9 on: Tue, 23 October 2012, 16:30:14 »
Huh...
Yep. That's the confusion. The "Pro" is a full keyboard, while the "Rapid" is a tenkeyless product.
Offline ih8
« Reply #10 on: Tue, 23 October 2012, 19:59:33 »
also I wouldn't recommend the pro to anyone
Offline ranunky
« Reply #11 on: Fri, 26 October 2012, 05:54:56 »
It is a quickfire pro with red switches. The last thing I wanted.
« Reply #12 on: Fri, 26 October 2012, 14:29:38 »
:( So picture wins out over description. Hopefully the return process goes well!
In Mail: HHKB Pro 2
Current: Endura Pro
