Author Topic: Chicony vs. Cherry blues  (Read 3701 times)
Offline Luke_A_P
« on: Tue, 23 October 2012, 09:49:52 »
Can anyone give me a subjective comparison of Chicony light blue clickys vs. Cherry Blues?
I have an old clicky Chicony I like certain aspects of it but not others. I have never tried Cherry blues and I’m trying to work out whether I would like them. Basically what I would really like is a backlit buckling spring tenkeyless, but I am pretty sure that is not going to exist in the near future. So I would like to know whether Cherry blues would be a good stand in.
I like the light touch of the Chicony but find it a bit too clattery and “loose feeling” compared to buckling springs. Are the Cherry blues more or less like buckling springs?
Luke
Re: Chicony vs. Cherry blues
« Reply #1 on: Tue, 23 October 2012, 10:09:42 »
The only way you will "work out whether I like them" would be to use them for some reasonable amount of time side-by-side.
The 2 blues are fairly similar, and while the Chicony (Monterey blue) may be a little "looser" to the feel, I find the sound and overall sensation preferable to the Cherry.
I recommend the O-ring modification to the Cherries, it makes the whole experience more "warm and fuzzy" and helps with the tinniness of the sound.
However, after using a battleship like a Model M/F, you will never find anything else that does not feel cheap and plasticy in comparison.
« Last Edit: Tue, 23 October 2012, 13:09:56 by fohat.digs »
- D Trump 2026-09-28
Offline Burz
  • maybe get a blister on yo' little finger...
« Reply #2 on: Tue, 23 October 2012, 11:32:59 »
Clicky Alps = Tom Jones
MX blues = Tiny Tim
 ;D
Matias Mini QuietPro  \\ Dell AT101W - Black ALPS  \\ SIIG MiniTouch x2 White XM - Monterey  \\ Colemak layout.
Offline hashbaz
  • Grand Ancient One
  • * Moderator Emeritus
« Reply #3 on: Tue, 23 October 2012, 11:39:45 »
I've used both and like both a lot.  The loose feeling you get with your Chicony is due to the build quality of the keyboard itself, not the switches.  A modern plate-mounted keyboard with MX blues (e.g., Filco, Leopold, Quickfire Rapid) is going to feel much more solid.
As for which switch feels better, that is entirely subjective.  If I could have the solid feeling and standard layout of a Filco with the Monterey blue switches from my Chicony, I think I would prefer that to an MX blue keyboard.  I guess I would say that MX blues feel closer to buckling springs than Monterey blues do ... but tbh all three feel very different from each other.
Ultimately, you gotta catch 'em all to know what works best for you.
Offline Luke_A_P
« Reply #4 on: Tue, 23 October 2012, 13:06:22 »
Thanks for the responses guys.
Out of interest, anyone know if the Monterey blues are still made?
Offline AKIMbO
  • HHKBro
Re: Re: Chicony vs. Cherry blues
« Reply #5 on: Tue, 23 October 2012, 22:30:57 »
They aren't but you can troll Ebay for Chicony 5181 boards. They show up fairly often.
| KBD75 (box reds)
Offline terrpn
  • Alpha Geezer
  • - Buy Vintage -
« Reply #6 on: Tue, 23 October 2012, 22:45:40 »
pretty accuate quip.......by hash
i have a chicony 5181 with monterey blues, a chicony 5161 with cherry blacks & a couple blue and a plate mount with blue cherries.
plate mounted blues are more clicky, rigid-- while the chicony 5161 blues are less clicky (but still tactile).
the chicony 5181 with monterey blues is tactile, while very light clicky.......less than the cherry blues. probably like it the most, but i think the 5161 weighs the most? good thing about the 5161 is it will take mx caps......
Luga G80-1865/MX Reds + Dolch G80-1813/MX Blues + G80-3700HQAUS + DK9008G2 Pro/MX Browns Thick PBT + DK9008G2 Pro/MX Clears Thick PBT +  QFR TKL/Ghetto Greens + Cherry G80-1800/MX Blues + IBM Model M SSK Bolt Modded + IBM Model M + IBM Model F + IBM AT F + Cherry G80-1000 (HAD)/MX Vintage Blacks + Razer BWU/MX Blues + Leading Edge DC2214/Blue Alps + Compaq MX11800/Browns + Chicony 5181/Monterey Blues + Chicony 5161/MX Black Cherry Clone + Focus 2001/White Alps + Chicony 5191/White Futabas + Olivetti ANK27-101 + Dell (Old Logo) AT101/Black Alps + NMB RT8255C+/Black Space Invaders + Unitek K260/Green Alps + Apple M0116/Orange Alps + AEK II M3501/Cream Alps + AEK M0115/Orange Alps + NEC  APC412/Blue Sliders + NEC APC410/Blue Sliders + Omnikey /White Alps + Wang/Yellow Alps (Omrons) + Laser/White SMK + Fame/Blue Aruz + AEK II M3501/Salmon Alps + Zenith ZKB-2R/Green Alps + Wang 724/Orange Alps + DK1087/Green Alps + Zenith ZKB-2/Yellow Alps + Dell Old Logo AT101/Salmon-Pink Alps + Leading Edge AK1012/White SMK's + Magitronic SK-1030/White (Linear) Futaba's + Packard Bell/White (Clicky) Futaba's + Datacomp DFK101/White  Alps + SGI AT101/Dampened White Alps + NMB AQ6RT-72511/Grey Space Invaders (Hi-Tek) + Datacomp/Blue Alps + Phillips 2812/White Space Invaders (Linear) + Dah Yang K251/Vintage MX Blues + Chicony 5161/DS Caps/Vintage MX Blue + Archie-NMB AQ659ZRT-725/Black Space Invader (Tactile) + IBM Model M 71G4644 (RD) Bolt Modded with Soarers Converter + IBM Model M Silver Label 1390131 + Cherry G80-1501/Vintage MX Clears + Focus FK8000/Linear Futabas + Gateway 2000 Anykey Programmable/Maxi-Switch + Dell GY13PVAT101/Dye Sub Caps/Salmon Alps + Chicony 5161/White Alps + AST K0B101/Slider over RD + Qtronix QX-32H + Everex/NMB RT8255CW+ Black Space Invaders-Split Erase + Tandon/NMB AQ659ZRT-101A/Beige Space Invaders + Cherry G80-11903 MNRUS/MX Blacks + Apple IIGS A9M0330/SMK Whites + WYSE PCE/MX Blacks + Chicony 5160AXT/Clicky Futaba + Cherry G80-0528/Vintage MX Blacks + Dell AT101/Linear (Modded) Black Alps+Topre 55g
Offline jacobolus
« Reply #7 on: Thu, 16 January 2014, 21:41:40 »
Dunno if it’s a good idea to necro this thread, but..
The cheap feeling of the Chicony has to do with the awful plastic case and the equally awful keycaps. I’m also not a big fan of the layout. Just pulling the plate + pcb out of the case entirely and setting it on a rubber mat for stability, and putting some keycaps from an Apple M3501 (this leaves some funny gaps, but just for the sake of trying the switches [and leave the original shifts and spacebar, since without stabilizers those are kinda terrible]) makes it feel quite dramatically better. With some better keycaps and a custom plate/case, these SMK blue-alps-slider switches should make a really nice keyboard.
Comparing to the Cherry MX blue.. the SMK-alps blue switches are slightly stiffer at actuation point, and the actuation point takes a bit less travel than the MX blues. Then force drops dramatically after actuation, so that it's quite easy to type lightly/springily on these switches. The original Chicony keycaps are thin, wobble a bit, and add a cheap hollow kind of sound to typing. With better keycaps added, the sound and feeling is very satisfying, a bit sharper sound and sharper tactility than the MX blue switches. I like it better.
[Though, my main criticism of the MX blue switches is just that the activation point is too low for my taste. This probably just boils down to personal preference.]
As was said upthread, if you compare a nice plate-mounted Cherry MX blue keyboard, with a solid case and nice thick keycaps directly to the Chicony 5181, it’s not unlikely that you’ll prefer the MX blue keyboard.
Note: I wish someone at Geekhack had (access to) the proper equipment for measuring force throughout the keypress accurately, so a few copies from different batches of each various type of switch could be consistently measured on the same equipment and proper graphs could be put up showing force on the way down/up, with actuation point marked. Ideally also showing the variance among same-model keyswitches, and the differing action of switches once they’ve been “broken in”, etc. You’d be able to very clearly see the differences between cherry MX blue and these SMK switches.
I’d really love to see the force graphs of all the various Alps & clone switches over the years, since there seems to be quite a broad range.
Edit: actually, that’s not quite right. I just tested again, and as it happens the click on the SMK “Monterey” switches happens about halfway through its range. It’s the genuine complicated Alps switches (e.g. tactile orange ones) that have a much higher activation point. I compared to some vintage MX blue switches again, directly, with and without keycaps, and the point of actuation is relatively similar between MX blue and Monterey blue. The real difference between the two is the sound, the tactile bump on the SMK switches is much sharper than on the cherry switches, there's less plastic-on-plastic friction throughout the keypress, and after the tactile bump/actuation point, force required to keep pushing the key drops to a very low amount. Also, the force required to push the keys to the start of the tactile bump is pretty low, just a bit more than the force exerted by resting the fingers on the switches. Maybe that's why they feel like the activation is nearer to the top: it takes less total work to get to the activation point.
« Last Edit: Sat, 18 January 2014, 18:21:35 by jacobolus »
Offline davkol
  •  Post Editing Timeout
« Reply #8 on: Fri, 24 January 2014, 06:47:04 »
There were chicony keyboards with Cherry MX Blue switches though... 5191
« Reply #9 on: Fri, 24 January 2014, 11:47:42 »
There's two people working on this project on GeekHack right now.
« Reply #10 on: Fri, 24 January 2014, 12:52:46 »
Cherry MX Blues:
* are less tactile than SMK blue clicky "Monterey" switches and buckling spring
* have hysteresis like the buckling spring, which the SMK don't have
* tactile mid-way, like SMK
* just as light as the SMK switches overall, but I suspect that the force curve is steeper on the SMK because of the shorter spring
I have a Chicony 5182 and it has a very creaky case, but the switches are in a steel plate. I rebuilt a Cherry G80-3000 case to host the innards (took a lot of plastic surgery to fit the plate), and it feels much better.
