Author Topic: Using foobar with iPhone  (Read 13042 times)
Offline baldgye
  • Will Smith Disciple
« on: Thu, 25 October 2012, 06:32:30 »
Anyone here know of a way to get an iPhone 5 to sync with foobar? I've pretty much had it with ****ing
iTunes, it's not even ****ing useable atm
Offline vun
  • Just one more thing
Re: Using foobar with iPhone
« Reply #1 on: Thu, 25 October 2012, 11:58:05 »
MediaMonkey is a decent alternative to iTunes.
As for Foobar, I've never used it with my iPod, but it does have a menu for iPod, I guess it works the same with iPhone. Should be File > iPod/iPhone > Synchronize, Manage Content or whatever you want to do.
Edit: I just found out you need a plugin to use it with an iPod, not sure if it works with an iPhone, but take a look around the hydrogenaudio forums.
« Last Edit: Fri, 02 November 2012, 15:36:30 by vun »
Offline Dabboo
« Reply #2 on: Fri, 26 October 2012, 20:58:31 »
I'd recommend SongBird. It has a massive range of plugins that will allow you to sync to iDevices.
I'm typing from a CM Quickfire with MX Blues.I'm also on a constant search for cool keycaps.
PM me if you've got any you'd like to send to Australia, I'm happy to buy!
Offline winzds
« Reply #3 on: Fri, 02 November 2012, 14:00:12 »
I don't know.  you can try QQ music.
Offline NKRO
« Reply #4 on: Fri, 02 November 2012, 20:43:33 »
What are the problems you're having with iTunes?
It may not be worth looking for an alternate right now when iTunes 11 is due later this month.
Offline vun
« Reply #5 on: Sat, 03 November 2012, 07:12:30 »
Check this thread and see if that's any help.
From what I gathered you need foo_dop and iTunes installed for it to work properly with iOS 5, if you're running 4 you should be able to use foo_dop without iTunes installed it seems.
