Author Topic: Broken K60  (Read 2380 times)
Offline TheQsanity
  • SmallFry Lovin'
Broken K60
« on: Sat, 27 October 2012, 00:01:39 »
I recently bought a used/broken K60. I Plugged it in and it powers on just fine. But the keys have a Ghosting affect when pressed down. What could the causes be? It ghosts many keys near it either through its column or row. What are the likely causes?
Thanks.
SmallFry! <3
Offline NV43
Re: Broken K60
« Reply #1 on: Sat, 27 October 2012, 00:15:18 »
It is a known problem in both the K60 and K90. They've tried to address it through firmware, but consensus is that it has not worked, and it is a problem that cannot be fixed.
Offline alaricljs
  • I be WOT'ing all day...
Re: Broken K60
« Reply #2 on: Sat, 27 October 2012, 09:02:56 »
Sell for parts?
Filco w/ Imsto thick PBT
Offline IvanIvanovich
  • Mr. Silk Underwear
Re: Broken K60
« Reply #3 on: Sat, 27 October 2012, 10:44:05 »
Put red switches in better keyboard... there is nothing much else to do with it.
Offline TheQsanity
  • SmallFry Lovin'
Re: Broken K60
« Reply #4 on: Sat, 27 October 2012, 17:10:46 »
Ill probably take the switches. What is the affected part? The controler? Could I still sell the pcb?
SmallFry! <3
Offline alaricljs
Re: Broken K60
« Reply #5 on: Sat, 27 October 2012, 17:54:59 »
Since they can't seem to fix it in the firmware, I'm betting the PCB is a big part of the problem.
Offline TheQsanity
  • SmallFry Lovin'
Re: Broken K60
« Reply #6 on: Sat, 27 October 2012, 17:58:38 »
Is it physical? I have seen some odd looking solder areas. Ill post some photos in a little.
SmallFry! <3
Offline alaricljs
Re: Broken K60
« Reply #7 on: Sat, 27 October 2012, 18:00:08 »
Chances are it's the matrix design far more than the quality of assembly.
