Author Topic: Color Keycaps For HHKB?  (Read 6209 times)
Offline Hyde
  • White Tofu Extraordinaire
« on: Sat, 27 October 2012, 12:48:20 »
I noticed they sell color keycaps for Topre Realforce but I don't see any for HHKB.  Or is it possible to salvage the extra keys or number pad keys and make shift to fit into HHKB?
Look like the short right shift will be the biggest issue isn't it?
Offline reaper
Re: Color Keycaps For HHKB?
« Reply #1 on: Sat, 27 October 2012, 13:32:41 »
Yup, you're right about the right shift but for me, you can hardly notice it.
And you can use any of the blank RF keycaps from EK (link).
« Last Edit: Sat, 27 October 2012, 14:02:52 by reaper »
Din Eli
Offline Hyde
« Reply #2 on: Sun, 28 October 2012, 21:51:44 »
Ohhhh cool !!!  Btw which key did you end up using for the right shift?  Caps Lock?
Offline whiskerBox
« Reply #3 on: Sun, 28 October 2012, 22:12:05 »
Or you could use the stock modifiers if you don't want blanks
Sorry for the crappy pic as usual
"I'm on a mission to bring down GH's anarchy of moderators" -RIPSTER jr.
