Author Topic: WYSE KU-8933  (Read 20415 times)
Offline NikoGasm
  • Platinum mad.
WYSE KU-8933
« on: Mon, 29 October 2012, 00:17:40 »
Is the WYSE KU-8933 mechanical or dome? I can't tell by looking at it, and I can't find any info on it.
Re: WYSE KU-8933
« Reply #1 on: Mon, 29 October 2012, 00:48:46 »
Offline NikoGasm
  • Platinum mad.
Re: WYSE KU-8933
« Reply #2 on: Mon, 29 October 2012, 01:00:39 »
Ah, thank you. I was unable to find any pictures of the switches.
Offline Donut
Re: WYSE KU-8933
« Reply #3 on: Mon, 08 April 2013, 12:24:36 »
Strangely, this YouTube video is supposedly of a Chicony KU8933 (which I would assume to the the same as the Wyse KU-8933). But the video seems to show a mechanical keyboard, and notice the casing design differs. Probably the uploader made a mistake with the model number and the video doesn't actually show a Chicony KU-8933.
Offline ander
  • I type, therefore I am
Re: WYSE KU-8933
« Reply #4 on: Sat, 30 December 2017, 02:11:47 »
I know this is an old thread, so make fun of me all you want... For reference purposes, though, the Wyse KU-8933 is a membrane board:
Re: WYSE KU-8933
« Reply #5 on: Sat, 30 December 2017, 04:15:14 »
A local hardware store chain uses it for their terminals. It is rubber dome.
