Author Topic: Some of my keys have become more stiff then others.....  (Read 1660 times)
Offline poisened_blueberry
« on: Mon, 29 October 2012, 02:53:39 »
f.x. my control key on the left side is alot more stiff now then it used to be, my 1-6 are more stiff then the 7-9, it's probably because i use those keys alot (i play sc2), how can i make them more loose again?
Offline perragnar
Re: Some of my keys have become more stiff then others.....
« Reply #1 on: Mon, 29 October 2012, 05:22:57 »
what keyboard are you using?
Offline theultrazord
« Reply #2 on: Mon, 29 October 2012, 13:18:19 »
Check out this switch lubrication guide. It might be that you need to lube those switches back up. I'm sure someone more knowledgable will come in with the exact answer though.
« Reply #3 on: Mon, 29 October 2012, 17:32:05 »
Oh i forgot to mention what keyboard i'm using, i'm using a filco majestouch red switch, oh and can you link me that guide ultrazord?
« Reply #4 on: Tue, 30 October 2012, 16:14:38 »
bumpity bump
