Author Topic: Make sure you put your keys in the correct order..  (Read 3087 times)
Offline MissMurd3r84
  • In IRC wondering why Kmiller8 is yelling.
« on: Mon, 29 October 2012, 06:29:49 »
So I was just browsing ebay instead of doing an assignment and decided to put a $10 bid on something..
I clicked it and went past the confirmation screen and didn't take much notice and next screen came up and umm well...
Current bid:   AU $10.50
Your maximum bid:   AU $1,000.00      :-X
I was wondering WTF happened, turns out my , and . were on backwards. I don't normally look at keys when I type, but for some reason when I was bidding I looked down and checked the keys rather than the screen. I had less issues with blank keys than I do with writing on them. So lesson learnt: Check keys are correct. I did have a good laugh about it though >.>
KBC Poker - Red switches. Noppoo Choc Mini - Black switches. Leopold FC700R (White) - Blue switches. Ducky YOTD - Brown switches. Razer BW - Blue switches and rusted.
Offline kinruan
  • SWAG=Specially Weaponized Asian Grandma
Re: Make sure you put your keys in the correct order..
« Reply #1 on: Mon, 29 October 2012, 09:39:01 »
You can retract your bid, search in the helping table
If the world ends tomorrow, what should we have for dinner tonight?
Offline laffindude
« Reply #2 on: Mon, 29 October 2012, 12:05:01 »
I am sure that warranted some facedesking. Watch the horn unicorn.
« Reply #3 on: Mon, 29 October 2012, 16:42:54 »
LOL sometimes I swap people's key caps around to see what they do, most here cannot touch type  :))
Offline IvanIvanovich
  • Mr. Silk Underwear
« Reply #4 on: Mon, 29 October 2012, 16:47:23 »
At least with $1,000 bid you can ensure victory in all but the most valuable item or extreme auctions.
Which reminds me I plan on doing this next weekend when I have to work around the office. They have those HP domes boards with all the same key profile for every row. Should be able to do some good ones.
« Reply #5 on: Tue, 30 October 2012, 00:03:55 »
I retracted it, but I couldn't help but to laugh at my own stupidity. Maybe next time I will take notice of the confirmation notice that pops up :p
