Author Topic: Tips for a beginner  (Read 3022 times)
Offline Scurq
  • potatoes.
Tips for a beginner
« on: Mon, 29 October 2012, 21:55:47 »
Hello everybody, I'm totally new here on GH as you probably can see.
I don't own any special keyboards and don't have any experience with keyboards and caps, but I'm going to try to learn more about mechanical keyboards and so on. I'm so interested in mechanical keyboards and I've read guides and stuff so I just thought like "why not buy a keyboard and modify it?" so that's what I'm probably going to do.
As the title says, I want to know some tips for beginners like me about different types of caps and switches and stuff like that so I can buy a good keyboard and start nerding!
Sorry for my extremly awesome english.
Thanks for reading!
I'm sorry for my awesomely bad english!
Re: Tips for a beginner
« Reply #1 on: Mon, 29 October 2012, 22:21:55 »
If you are comfortable with tinkering, cleaning, and adjusting, it is often possible to find dirty old keyboards on ebay that can be made good again.
IBM Model M keyboards are built like battleships and are satisfying to restore.
- D Trump 2026-10-24
Offline Scurq
  • potatoes.
« Reply #2 on: Mon, 29 October 2012, 22:26:21 »
I forgot to say that i live in sweden so im using swedish ISO-layouts! Other keyboards cant write three very important letters, åäö.
Offline wetto
  • Brazil's Keyboard Enthusiasts Representative
    • Portuguese Mechanical Keyboard Guide
« Reply #3 on: Mon, 29 October 2012, 22:39:12 »
Yes, they can, all you need to do is properly set it to Swedish - US International (THIS IS IMPORTANT!) Layout:
Go to your Input Languages on your Operational System:
And open "Change Keyboard".
Click on "Add" and find "Swedish (Sweden)" and click on "Show More":
And then, scroll down until you find US - International:
Activate it, click on OK, set it as default and remove all the other keyboard layout that aren't Swedish - United States - International.
It should become like this:
It MAY not work at first, because some of your apps may still be using the old layout, so, if it doesn't works as soon as you did this (or works on some apps and not on others), just restart your computer.
I DO NOT recommend keeping more than ONE keyboard layout, since Windows is actually quite tricky and may do stupid stuff like changing layouts when you less expect.
Now, all you need to do is:
CTRL + ALT + W = å       (Or ALT GR + W if the keyboard has ALT GR)
" + o = ö
" + a = ä
I write in Brazilian Portuguese using an US-ANSI keyboard with no trouble at all. We use letters like "é, ã ó, à, á" a lot and I don't have any issues at all.
« Last Edit: Mon, 29 October 2012, 22:59:22 by wetto »
My collection:
Mice: Logitech G602, CM Storm Recon, CM Storm Spawn, Razer Naga, Ozone Radon Opto, Corsair M60, Tesoro Gandiva, CM Storm Alcor, Mionix Naos 8200.
Keyboards: Matias Secure Pro, Matias Mini Quiet Pro, custom modded Metadot Das Keyboard Model S Professional Silent (MX Brown, Costar), CM Storm Trigger (MX Brown), Noppoo Choc Mini (MX Red), Tesoro Lobera G5NFL Supreme, CM Storm Devastator.
Soon: CM Storm Quick Fire TK (MX Brown), CM Storm Trigger Z.
Boards I don't own anymore: CM Storm Quick Fire Rapid (MX Black), Logitech K800 (Membrane), Logitech G710+ (MX Brown), Thermaltake Meka G-Unit (MX Black), Corsair K70 (MX Red).
Mice I don't own anymore: Logitech G9x MW3, Corsair M65, Logitech G700, Roccat Kone Pure.
Offline jeroplane
« Reply #4 on: Mon, 29 October 2012, 23:09:36 »
Apologies if you've seen these already, but everyone's first ports of call for getting into mechanical keyboards:
OCN Mechanical Keyboard Guide
Deskthority Wiki
My signature hasn't changed since 2012. I should really update it.
Offline Hyde
  • White Tofu Extraordinaire
« Reply #5 on: Tue, 30 October 2012, 00:22:32 »
Here is how I'd summarize the switches for you, keep in mind everyone like different switches so this is only rough guideline:
Buckling Spring: Very Loud and Very Clicky.
Cherry MX Switches:
MX Blue => 80% Typing 20% Gaming => Clicky Sound Clicky Feel => Medium Pressure
MX Brown => 60% Typing 40% Gaming => No Sound Clicky Feel => Light Pressure
MX Red => 40% Typing 60% Gaming => No Sound Linear Feel => Light Pressure
MX Black => 20% Typing 80% Gaming => No Sound Linear Feel => Hard Pressure
Topre Switches:
Hybrid of Rubber Dome and Mechanical Switches => $300 => Expensive
If you're new to this I'd say start with the 4 common MX switch types first, maybe go to a local computer store and try them out.  The common ones you can find are Das Keyboard (MX Brown and MX Blue), Razer Blackwidow (MX Blue), SteelSeries 6GV2 (MX Black and MX Red), Corsair K60 and K90 (MX Red), CM Storm Trigger (MX Brown and MX Red), CM Storm QuickFire Pro (MX Brown), ThermalTake MEKA G1 (MX Black)... etc
« Last Edit: Tue, 30 October 2012, 00:27:11 by Hyde »
Offline Scurq
  • potatoes.
« Reply #6 on: Tue, 30 October 2012, 10:28:38 »
<img>
<img>
<img>
<img>
<img>
" + o = ö
" + a = ä
Oh, thanks i didn't know that! But yeah, i want a swedish keyboard at first.
Deskthority Wiki
Ive already read those, thanks anyway!
Cherry MX Switches:
Topre Switches:
I know about this a little bit and ive tested out some keyboard switches and i really love mx reds and browns so that's what im going for. and maybe mod some blacks into ghetto reds on a quickfire or something.
