Author Topic: Can anyone who owns any Quickfire Rapid clarify for me...  (Read 7529 times)
Offline KillVolume
« on: Tue, 30 October 2012, 02:06:47 »
I've never felt PBT keys before, but I've heard they have a textured, almost chalky feel. I own a Quickfire Rapid, and noticed that the red WASD keys they come with seem to have a different texture than the rest of the keys, and don't quite feel like regular ABS. It's especially easy to tell if you run your nail along them. Can anyone more knowledgeable than me clarify whether the red keys are PBT, or why they feel different than the other keys that ship with the board?
Offline squarebox
  • In Omnia Paratus
Re: Can anyone who owns any Quickfire Rapid clarify for me...
« Reply #1 on: Tue, 30 October 2012, 02:47:51 »
They are still ABS but probably uncoated.
Filco Yellow Edition  | Filco Brown | Filco 2 Brown TKL | G80-1950 | G80-3494 | G80-11900 | Leopold FC500R | Noppoo Choc Mini
Offline KillVolume
« Reply #2 on: Tue, 30 October 2012, 03:00:12 »
That makes sense. Is it similar to the feel of PBT? Because whatever it is, I don't think I like the texture.
Offline Terrorsathan
« Reply #3 on: Tue, 30 October 2012, 07:19:21 »
I am typing this response on a CM STORM QFR... the stock keys are low quality/printed ABS keys....  I do not mind ABS if they're decent quality/profile.
Offline KillVolume
« Reply #4 on: Tue, 30 October 2012, 08:05:05 »
I am well aware of that. I'm just wondering why the included red WASD keys feel different than the rest of the stock keycaps.
Offline alaricljs
  • I be WOT'ing all day...
« Reply #5 on: Tue, 30 October 2012, 10:08:56 »
No they don't feel anything like PBT
Filco w/ Imsto thick PBT
Offline HRS2K
  • I love Blue!
« Reply #6 on: Wed, 31 October 2012, 09:39:43 »
they are bad keys. i didnt use them long, maybe a month with typical use everyday use. They already need to be replaced. Looks like they get dirty.
KBC Poker (Blacks), CM Storm QuickFire Rapid (Blues), Leopold FC200RC (Blues)
« Reply #7 on: Wed, 31 October 2012, 18:09:49 »
The replacement "Cooler / Master" modifier keys are made differently than the normal ones. I'm not sure about the red WASD arrow ones, but I think they are, too. I'd say this is just a difference in ABS.
You should get PBT for it. I have SP PBT on mine, and it's awesome.
Offline Lu_e
« Reply #8 on: Thu, 01 November 2012, 19:38:45 »
The CM WASD set that came with my kb was 'rubberized' much like the QFR's case/chassis. I wouldnt doubt its the exact same process.
Just say NO to ABS keycaps
Offline WhiteFireDragon
    • youtube
« Reply #9 on: Thu, 01 November 2012, 21:39:15 »
Oh is this so? This is news to me. The 3 that I have are not rubberized.
Offline Rinsaku
  • lorem ipsum
« Reply #10 on: Fri, 02 November 2012, 05:03:59 »
the cm keys are pretty slick. Pbt feels better
Current Boards : Apple m0116 (Salmon Alps), B.Face (Mx Clears), Filco Tkl (Mx Blues), HHKB Pro JP (Topre), Jd45 (78g Zealios), KBParadise v60 (Gateron Yellows), KBParadise v60 (Matias Quiet Click), Kbt Pure (Kailh Bronze), Leopold FC660M (Mx Browns), Minidox (Mod-H), Pok3r (62g Zealios)
« Reply #11 on: Fri, 02 November 2012, 06:06:38 »
Fwiw the extra keys that came with my CM QFR seem to be identical to the black keys, except red, and with slightly different markings.  Certainly not rubbery in any way.
Offline KillVolume
« Reply #12 on: Fri, 02 November 2012, 08:05:48 »
The black keys on my Rapid are slick. The red keys are a little more textured.
I couldn't really get a good picture. It's really more how they feel. Try scratching both of them with your fingernail and see if you feel a difference.
Offline modulor
« Reply #13 on: Fri, 02 November 2012, 09:17:51 »
I find the texture of PBT to be quite nice for both typing and gaming, they seem to have just the right amount of texture.  This is not to say I don't enjoy my ABS keys, though.  I never checked the stock QFR keycaps, as I took all of the originals off as soon as I got the board to modify it and then added PBT caps.  Texture varies from manufacturer to manufacturer, but maybe the red keys have a slightly rougher texture for gaming.  I'll have to compare and contrast this weekend :)
NP-R (soon) | 21XX | Leggera-G Acrylic | Classic TKL | Frog TKL 8K | GH60revC | R1 86U 45g | G80-2100HDU | G80-3000HAU | G80-3700HAU | QFR V1 | FC200R | Poker X | G80-11900LUMEU
Offline laffindude
« Reply #14 on: Fri, 02 November 2012, 10:01:26 »
Mine has different red WASD as well. They're stiffer ABS than those on the regular keys (and no rubberized coating). Regular keys have a softer feel to them much like the Ninja keys. Incidentally, they're both black lasered keys. Could be something to do with that. I know there is different compound they use for lasering. May be they only use that on black keys so the legends come out whiter. Multicam is also lasered, though they don't feel as soft as those previous keys. Not sure why. Red WASD is also lasered, but not may be they don't need the different mix for the lasering to come out white.
« Reply #15 on: Sat, 03 November 2012, 05:17:38 »
Exactly the same.
Offline Lu_e
« Reply #16 on: Sat, 03 November 2012, 20:53:30 »
Mine are DEFINITELY different than the oem keycaps, and I stand by my rubberized statement.
I just checked again and they look nowhere near as glossy as rowdy's, they look and feel matte. They also feel very similar to my QFR's rubberized case.
« Reply #17 on: Sun, 04 November 2012, 15:38:58 »
How similar ore they to the Corsair rubber keycaps? Can you take a picture comparing the "rubberized" cm keycaps to a normal one?
Offline suprsmo
  • Sydney, Australia
« Reply #18 on: Sun, 04 November 2012, 16:20:09 »
Odd. My wasd caps are the same as rowdys. I didn't even take them out of the bag until now!
Poker
QFR
« Reply #19 on: Sun, 04 November 2012, 21:51:29 »
Maybe Aussie-distributed ones are the same?  Or an older batch of keyboards?  I do know that my QFR was the last one in stock at CPL in Melbourne.  The day after I picked up mine the item was out of stock, and a couple of weeks later came back in stock.
Now I am wondering whether this new batch has branding or not.
And rubberised WASD replacement keycaps.
Offline laffindude
« Reply #20 on: Mon, 05 November 2012, 07:21:06 »
It could be PU/UV coated like Filco pad printed caps.
Offline Lu_e
« Reply #21 on: Tue, 06 November 2012, 01:23:00 »
« Reply #22 on: Tue, 06 November 2012, 02:48:45 »
^ That one has something stuck on top of the keycap.
Mine does not.
« Reply #23 on: Wed, 07 November 2012, 09:48:17 »
I don't think it's anything older/newer. I have one of the older QFR's in Red, and a pretty new (Not brandless, though) QFR in blues. Both have the same keycaps.
Offline Lu_e
« Reply #24 on: Sat, 10 November 2012, 14:26:57 »
Well my brandless qfr red came with a rubber coated WASD set :p
I'm sure others (who got brandless) just haven't noticed.
« Reply #25 on: Sat, 10 November 2012, 22:08:28 »
I didn't like the font on the keycaps, so the first thing I did was replace everything (except the space bar) with alternative keycaps, thus I did not even look at the red WASD keys.
