Author Topic: Freestyle Scratchbuilt Bench Build A.K.A. The 8 Hour Challenge  (Read 2518 times)
Offline dieseldog49
« on: Thu, 01 November 2012, 21:04:59 »
Hey guys, so I snagged a bunch of stuff at the Dangerden Fire Sale (Sad to see them go :sad-smile ) and I was jazzed with all of these parts headed my way and I was in the "modding" mood. However I am waiting on parts for my Bombproof Builders Desk and my Wall PC build. So knowing I needed a new benching station (traded away my Dimas) I got a crazy idea, build a bench from scratch and only give myself 8 hours to do it! Not only that but I decided I had to use free and found parts as much as possible and I had to make it up as I went along. No sketches, plans or CAD layouts. But wait theres more! I also decided I could not make any measurements, I would have to find templates or eyeball it, the only thing I could use was a strait edge, everything else would be improvised or found objects.
Now why would I put all of these totally unnecessary "limits" on myself? Well several reasons
1. If it isn't hard it's not worth doing. I live for challenge and its one of the main reason I build PC's.
2. To shake things up! I currently have my next 5 Desk/Case/Scratch  builds planned out extensively (which by the way should end up being about 2 years worth of builds :thumb: ) But I can only take those on one at a time and between work, cashflow and life there can be stretches where I dont even get to work on them. By playing playing by an entirely different set of rules I force myself to think and create in entirely new ways and explore the dynamics of my creative proccess.
3. Success Teaches us nothing, We only learn from failure. I knew going into this build with these rules I was going to screw things up, but thats the beauty of this build is that every mistake I made i had to adjust to and improve upon. Even this far in I have already come up with a ton of better ways to work with my builds and perfected some of my techniques along the way.
DISCLAIMER: This is a build for the fun of it. It in no way reflects my standards for regular case modding or scratchbuilding I am just having a good time and taking the attitude of as long as it fits we're good.
Ok so lets get into this build, the platform I am going to be using is a piece of scrap plywood from my desk build. I took a broken Asus Z68 Deluxe mobo and used it as my template for my standoffs. I then drilled the holes and threaded my standoffs in very very carefully :weirdsmil
First 4 in
Pretty happy with how it lined up
Then the Rest, not perfect but close enough (30 minutes in)
But dont think I have forgotten the mATX boards!
Bah one standoff short
Now we need to mark out some cable management holes
And its off to the Sawhorses!
First one was pretty rough
But with the second one I had gotten it pretty close to figured out
Third one was as close to perfect as I think I can get freestyling it
Now to the first leg,  using 2x6 scraps from closing in my carport, didn't even cut them to fit this. (70 minutes in)
Pre-drilled then screwed in the leg
But then inspiration hits (I blame the Jawas, Utini!)
Beer decided to explode from vibration
Next up we have the 360mm rad cutout (thats right I am going for the gold here) (110 Minutes in)
Rough left side cut
Cleanin up
Side Cut for the right
Cleaned up a bit
Figuring out where I need to drill my mounting holes
Test fitting
Where I am at 2 and a half hours of work
Next steps
PSU Mount
HDD mounts
PCIE Bracket
Router the Edges
fix some of the wood imperfections
Power and Reset Switches
USB ports
a Coat of High Gloss paint.
Offline TheQsanity
  • SmallFry Lovin'
Re: Freestyle Scratchbuilt Bench Build A.K.A. The 8 Hour Challenge
« Reply #1 on: Fri, 02 November 2012, 02:05:21 »
A computer case bench? Would this have heating issues?
SmallFry! <3
Offline dirge
« Reply #2 on: Fri, 02 November 2012, 04:08:10 »
Nice work, watching this thread now :)
powertools > keyboards
Thinking about things isn't the same as doing things. Otherwise everybody would be in jail.
Offline dieseldog49
« Reply #3 on: Fri, 02 November 2012, 09:40:59 »
Qsainity benches are a very popular item these days for overclockers and system builders, it lets you test all of the components before mounting them in the case. They have no heating issues and in my experience they run cooler cause nothing is restricting airflow. heres a picture of one I had bought from a company in Italy called Dimas Tech
Offline boost
  • BOSTMOBILE
  • NY Giants!!!
« Reply #4 on: Fri, 02 November 2012, 09:47:54 »
Very nice bench and supports watercooling :). Can't wait to see the finished product.
-Enzo Ferrari
Offline thegunner100
  • (╯'□')╯︵</3 ノ( '-'ノ)
    • The Emotional Skyscraper
« Reply #5 on: Fri, 02 November 2012, 09:51:23 »
Can't wait to see the end product, gj!
Input Devices:CM QF Rapidx2 ~ REALFORCE 87uw 45/55g ~ Logitech G5v2 ~ Wacom Bamboo CTH-460
Audio Setup: look me up on head-fi
Check out my blog on touhou/doujin music, audiophile gear, and doujin games!
