Author Topic: CmStorm quickfire pro too slow for boot  (Read 2652 times)
Offline mariusmssj
« on: Mon, 05 November 2012, 13:27:46 »
Hey guys.
Just realised that I can't get into BIOS menu when my PC boots, it seems like keyboard only get's powered on when the Windows 7 is almost fully loaded.
Yet my Razer keyboard has no issues starting right away with my PC.
Any suggestions how to overcome this issue?
Cheers
CM Storm QuickFire Pro [MX RED]
Offline alaricljs
  • I be WOT'ing all day...
Re: CmStorm quickfire pro too slow for boot
« Reply #1 on: Mon, 05 November 2012, 13:34:55 »
Is this true with a warm-reset?  (ie: machine is on, hit the reset button or tell windows to restart)
Filco w/ Imsto thick PBT
Offline mariusmssj
« Reply #2 on: Mon, 05 November 2012, 13:42:44 »
Both cold and warm
Offline alaricljs
« Reply #3 on: Mon, 05 November 2012, 13:54:26 »
Considering it's USB NKRO, the implementation might be incompatible with your BIOS or BIOS in general.  Which is not cool.  So basically you need another KB to get into your BIOS.
Offline mariusmssj
« Reply #4 on: Mon, 05 November 2012, 13:55:43 »
I got this :
But i don't use it, would it help?
Offline alaricljs
« Reply #5 on: Mon, 05 November 2012, 13:56:25 »
Did it come with the KB?  Because the specs on CM's site don't say anything about PS/2 at all, just USB.
« Reply #6 on: Mon, 05 November 2012, 13:57:31 »
Not entirely sure if it is compatible with the controller.... I know the rapid is, but I had never used a USB->ps/2 converter with Pro.
Offline mariusmssj
« Reply #7 on: Mon, 05 November 2012, 14:00:21 »
It didn't come with the keyboard and since my keyboard is partially backlit i don't think that it will even work :(
But it used to work before, I was able to get into bios just fine pressing "DEL" key but i had issue when it come to using the keyboard in boot menu
Offline Hyde
  • White Tofu Extraordinaire
« Reply #8 on: Mon, 05 November 2012, 14:47:27 »
I'd say turn off NKRO and switch back to 6KRO before you reboot, see if that works.
Offline mariusmssj
« Reply #9 on: Mon, 05 November 2012, 14:51:22 »
Does it matter if i use USB 3.0 or 2.0 ports?
Offline stingrae
« Reply #10 on: Mon, 05 November 2012, 14:57:01 »
Not likely.
It may matter if you enabled/disabled legacy usb support. It 'should' work with 6kro mode in bios. The ps2 adapter probably wont work.
Filco Ninja Tenkeyless  -Noppoo Choc MiniCm Storm Quickfire Rapid
