Author Topic: [GB] Klaxon! The RA2.0 clone - Orders closed! Invoicing/revision time  (Read 557871 times)
Offline pasph
Re: [GB] Klaxon! The RA2.0 clone - Orders closed! Invoicing/revision time
« Reply #1100 on: Thu, 07 February 2013, 15:55:36 »
^ I fear that may be the reaction of many...
USPS new rates and now this?
Not worth imho, a RoW base+mods=$48
Better buy another ansi kb
Offline tjcaustin
  • King Klaxon
    • Buy stuff
« Reply #1101 on: Thu, 07 February 2013, 16:32:27 »
Okay then.
If the 25 of you want to choose your own color of the three, that's fine.  Any color will have to obviously meet the MoQ of 10 orders.
OR.
We stick with the original plan of WoR only.
Offline redeye
« Reply #1102 on: Thu, 07 February 2013, 16:35:24 »
WoR iso's are good for me.
Offline Lighthouse1
« Reply #1103 on: Thu, 07 February 2013, 16:52:46 »
I dont mind all 3 sets I am sure people will want trade them etc and its a pain getting ISO, but if its one set that's fine too.
Offline adrock
« Reply #1104 on: Fri, 08 February 2013, 05:33:03 »
Hello, I'me George's ISO loving friend  >:D
What exactly is included in the ISO kit, and in what colours? I'm only going with a RoW base set, but I'll have both RoW mods and WoR mods, so I'm not sure which would fit best.
I've a full size filco mj2 I'd like to put these on (and periodically swap the mods).
Offline la3195
« Reply #1105 on: Fri, 08 February 2013, 05:56:17 »
I don't mind paying for all ISO three sets.  I want RoW to match the rest of my keys. And as it looks like WoR was the more popular I was going to end up with a miss match (might've looked cool though)! I will buy all three and then someone can buy the other two sets from me ;P
L
Offline realex
« Reply #1106 on: Fri, 08 February 2013, 06:26:01 »
i think you should just offer the most voted iso set as default. any modifications to it should be paid for by the ones who actually need them and not by the entire majority of iso buyers, who, in many cases my not even have remote use for the other options.
i also think, the possibility of selling the extra sets after being forced to take all 3 is not an option. theres definitely not a lot of people around to soak up such a specific niche of products. ("hey sup, do you happen to look for a red alert RoG ISO adapter kit? yeah sure i'll take 10")
« Reply #1107 on: Fri, 08 February 2013, 06:55:13 »
Yeah, I think in the end TJ will stick with WoR as the only ISO option. Even if you only ordered RoW base and mods, it will still look good. Having all keys of one color, with one or two as a contrast, looks really good to most people.
Offline pasph
« Reply #1108 on: Fri, 08 February 2013, 07:15:29 »
Enter, left shift and the near key all and only these?
I don't think so, don't try to make it look like a good opportunity, ISO here is always a matter of trade-offs
Offline BimboBB
« Reply #1109 on: Fri, 08 February 2013, 07:56:34 »
As already stated, I would prefer WoR for the ISO kit and was assuming this was more or less confirmed. But would be happy to get the RoW ISO kit as well. Didnt understand why there wasnt at least two(three) ISO kits when offering two(three) different base kits.
Maybe its possible to make a quick extra poll for the ISO buyers, if they want a 2nd ISO kit?
Offline danielucf
  • Horrible Mailman
  • Hmmmm beer.
« Reply #1110 on: Fri, 08 February 2013, 08:18:17 »
Concerning iso kits:
Supposedly when you run color combinations of the same thing at Signature Plastics if it is the same colors just reversed they can fall into the same pricing tier. lets just say you had 25 RoW and 25 WoR, you would actually hit the 50 tier price point instead of two 20 tier price points. This would save $5 per iso set for those two colors.
You do have to double check with Melissa though since this could bring down the cost of everything WoR and RoW and it may not apply to full sets but just solo keys, or smaller sets of keys.
Offline mickd
« Reply #1111 on: Fri, 08 February 2013, 08:23:02 »
Has that been done in the past Daniel? I was always under the impression that regardless it will have a separate MOQ.
« Reply #1112 on: Fri, 08 February 2013, 08:26:24 »
I wasn't trying to. TJ really only has one option, and that's to leave it as is, and keep it WoR only. ISO in GB's here is always a compromise, as there just aren't that many orders to make it cost effective, and at the same time to give those interested many options. This GB isn't like 7bit's R4, and never aimed to be.
I know of several European/UK members who use ANSI standard keyboards. This gives them a good opportunity to participate in any GB and get nice looking custom keysets for their keyboards.
« Reply #1113 on: Fri, 08 February 2013, 08:29:02 »
I've never heard of that happening. Do you have an example of where that happened? Because every GB I've participated in has had separate price tiers for each color, even just reversed combos.
Offline danielucf
  • Horrible Mailman
  • Hmmmm beer.
« Reply #1114 on: Fri, 08 February 2013, 08:52:55 »
This is why the vendor set is going to be cheap in the Toxic group buy which is why it may not apply to entire sets. It could apply to iso though since it is less keys. When you order an 87 key set over 100 orders that is 8700 keys which can be pretty cheap, yes that is 100 sets of 87 keys essentially, but normally a SET of keys is cheaper than doing 87 different orders of individual keys. I think the set is cheaper because the tiers add up to a reduction somehow.
Offline GeorgeK
« Reply #1115 on: Fri, 08 February 2013, 09:02:02 »
If that is the case then wouldn't all the sets drop tiers?  You'd be on 265 RoW / WoR base sets for example...  That would be awesome!
Offline RinSewand
« Reply #1116 on: Fri, 08 February 2013, 09:43:17 »
As stated before I'd be up for all three ISO kits - I need RoG and WoR anyway, if its going to be WoR only then ill need to cancel my RoG mods order as that wouldn't look too great.
Offline pasph
« Reply #1117 on: Fri, 08 February 2013, 10:00:01 »
I agree, in fact i've said: ok with 1 color but if it's a pack of 3 colors for $45 i'll drop ISO and buy an ansi kb!
I don't want to debate iso vs ansi but for sure paying 9 keys (they are blank?) the same amount of 87 it's not my best hope
Offline danielucf
  • Horrible Mailman
  • Hmmmm beer.
« Reply #1118 on: Fri, 08 February 2013, 10:15:45 »
I think when it comes to larger sets the discount is already baked in since it is so many keys. That is why it applies to single keys like "geek hack" keys in both colors being the same tier potentially.
Offline aggiejy
« Reply #1119 on: Fri, 08 February 2013, 12:06:52 »
danielucf...  I'm almost certain that isn't the case.  Larger sets are quoted independently like you say, but for smaller sets when going by the price sheet, color breaks the MOQ.  I've recently confirmed this with her as well, and even followed up twice just to make double-sure... as it would certainly change group buys in a big way.  I wish it were true though, so if you know something I don't, let me know! :)
Offline tjcaustin
  • King Klaxon
    • Buy stuff
« Reply #1120 on: Fri, 08 February 2013, 12:46:17 »
In fact, that was verified earlier in this thread as it was one of the recent things I discussed with Melissa to help people out.
They're not and it's 4 keys per set(I still see that point even though it's 12 keys total) - http://keycapsdirect.com/pdfs/ISO4Key.pdf
Actually, 5 because I got them to add the proper 2 key to the kit as well.
Offline Mysteric
  • Formerly 'Mackem'
« Reply #1121 on: Fri, 08 February 2013, 12:49:09 »
It would look fine except that a WoR number 2 key would look strange with a RoW base set, the other keys not so much. If you can give me a quote on the potential costs for my order (1 x RoW base kit, 1 x WoR modifiers, ISO kit), I can weigh up my options and let you know from there (Not necessarily an 'official' invoice, just a ballpark figure.
Offline tjcaustin
  • King Klaxon
    • Buy stuff
« Reply #1122 on: Fri, 08 February 2013, 12:52:59 »
The keys are going to be around $87 shipped before ~$9 in sorting/paypal/subsidy(for RoG base kits, it's like a dollar)
Additionally, I've got about 50 people that I still have no way to bill.
« Last Edit: Fri, 08 February 2013, 12:54:33 by tjcaustin »
Offline Mysteric
  • Formerly 'Mackem'
« Reply #1123 on: Fri, 08 February 2013, 12:57:06 »
Ouch, that's a fairly large sum, would've had no problems paying say $75-$85 in total. I really want these keycaps as well, red and white are my favourite colour combination :(
Offline tjcaustin
  • King Klaxon
    • Buy stuff
« Reply #1124 on: Fri, 08 February 2013, 13:25:54 »
Yeah, that's the crappy part about the low tier pricing.  Even at 25 people, ISO is still more than 50% of the price of the two base kits.
The only other way I can think of is to make everyone bear the burden through subsidy.  Essentially cap the price of ISO, then spread the difference over everyone's order.
I'm extremely hesitant to do this because I don't want to be the GB of "I would have got it, but he added so many fees..."
Offline aggiejy
« Reply #1125 on: Fri, 08 February 2013, 15:07:12 »
I assume you're still sending invoices?  I haven't gotten one, nor a PM, so just making sure I'm not one of the deadbeats. :)
Offline tjcaustin
  • King Klaxon
    • Buy stuff
« Reply #1126 on: Fri, 08 February 2013, 15:08:19 »
I would like to send them all at once and I still have about 50 people that haven't sent me any paypal info.
Offline aggiejy
« Reply #1127 on: Fri, 08 February 2013, 15:08:34 »
Oh, I see, thanks!
Offline akuJIWA
  • Lock 'N Load!
« Reply #1128 on: Fri, 08 February 2013, 15:23:11 »
tj, I confirm my order. Let me know when you've sent the invoice!
The Cheat - B/R/B ; Clear switch with 62g springs
quit
Offline Supergleep
« Reply #1129 on: Fri, 08 February 2013, 18:03:31 »
Just to confirm, if we filled out the updated questionnaire on the front page that included our paypal info, we're covered? Or do we need to send you a PM with paypal info?
Filco Tenkeyless - Daily Driver  |  Filco Linear R - 87  |
Offline jabar
« Reply #1130 on: Fri, 08 February 2013, 18:08:50 »
If you filled out the standard vs. 7bit mods plus Paypal info, you're covered.
Leopold FC660C - Max Keyboard Nighthawk X8 - Ducky DK9008 Shine II 78 Edition - Noppoo Choc Mini - Cherry G80-2100HDD - Cherry G80-8113HDPUS - Plu-M87 - Leopold FC700R Ergo Clears - Deck Legend Frost 105 - IBM F PC Keyboard - IBM M 122 (Lexmark) - Apple Extended Keyboard II
Phantom 7bit
Offline tjcaustin
  • King Klaxon
    • Buy stuff
« Reply #1131 on: Fri, 08 February 2013, 18:17:59 »
Form filled = covered
Offline tauburn
« Reply #1132 on: Fri, 08 February 2013, 18:57:20 »
to be honest, people who cant figure out such a simple form deserve to be left behind
Offline redeye
« Reply #1133 on: Sat, 09 February 2013, 03:44:22 »
I agree but 50 people = lots of dosh. Also equates to increase of tiers and a Major headache
Offline damorgue
    • Personal portfolio
« Reply #1134 on: Sat, 09 February 2013, 03:50:47 »
I too am only interested in RoW. All three seems like the best compromise to me.
Offline GeorgeK
« Reply #1135 on: Sat, 09 February 2013, 07:42:58 »
Exactly - it's annoying but prices will increase (possibly by a lot) if people are left behind (or if they don't pay up etc)
Offline Mysteric
  • Formerly 'Mackem'
« Reply #1136 on: Sat, 09 February 2013, 13:10:39 »
I may still be in for all three ISO kit colours. tjcaustin, is it possible to get a RoW keycap for the number 2 key with the " on it as a one-off? It'd match my RoW base kit then :) I'd be interested to see how much it would be.
Offline MadScientist46
  • Snaged his first CCs -> HappyScientist now ^_^
« Reply #1137 on: Sat, 09 February 2013, 18:57:17 »
Noppoo Choc mini MX-Reds | KBT Pure MX-Reds/Green LEDs
Offline tjcaustin
  • King Klaxon
    • Buy stuff
« Reply #1138 on: Sun, 10 February 2013, 11:19:23 »
Going to give the 35 people left until the end of today to get me paypal stuff and then hounds will be set free
Offline Sai
« Reply #1139 on: Sun, 10 February 2013, 11:25:44 »
nice !
Offline LechnerDE
« Reply #1140 on: Sun, 10 February 2013, 12:12:00 »
**** YEAH!!
 :D
Offline GeorgeK
« Reply #1141 on: Sun, 10 February 2013, 12:39:16 »
Good stuff - just as a hypothetical, what happens if they don't get in contact / pay?
Offline do_Og@n
« Reply #1142 on: Sun, 10 February 2013, 12:56:44 »
Can I still place an order for the WOR and ROW sets?
Offline iArson
« Reply #1143 on: Sun, 10 February 2013, 13:13:13 »
PM'd TJ :D
Forgot all about the message you left me!
Offline tjcaustin
  • King Klaxon
    • Buy stuff
« Reply #1144 on: Sun, 10 February 2013, 13:27:58 »
Yup, just fill out the forms in OP, please.
IP traces, murder, identity theft, order fulfilment
Offline GeorgeK
« Reply #1145 on: Sun, 10 February 2013, 13:33:24 »
Fair enough, sounds reasonable and proportional - as long as it's all in hand :D
Offline megaforce
« Reply #1146 on: Sun, 10 February 2013, 13:34:53 »
Are these Cherry or OEM profile?
Corsair K63 Wireless | Razer Huntsman Elite
Hokusai | Ogre| Yohane | Mc65 | Kaze | RBB
Former: LZ MX | LZ FE | LZ CLS TKL Silver |LZ CLS TKL Gray| LZ St | V.EA | Blackbird | LSV3 | OctagonV2 | Norbatouch | X60 | TX84 | Kyuu | SSK | 268.1| Jane CE | Corsair K95 | X60R | HHKB JP x JS HiPro | 910 CE |Nunu |Nunu FE | Jane V2 CE|Jane V2| RS (TKL)
Offline inteli722
« Reply #1147 on: Sun, 10 February 2013, 13:53:24 »
Combination that's unique to Signature Plastics. I think it's closer to Cherry, but it's not exact.
Waiting for: Phantom Plate
Offline Gupgup
« Reply #1148 on: Sun, 10 February 2013, 13:57:08 »
Form filled, hopefully did the right one..? Haven't been keeping up on this :/
« Reply #1149 on: Sun, 10 February 2013, 14:05:12 »
If there are some Europeans to be punished, just PM me with the details and I'll take some days off for a nice trip....  ;D
Right, not exactly the same. Main difference is the bottom row which has a bigger angle than Cherry profile (dunno how to describe better).
