Author Topic: [GB] Klaxon! The RA2.0 clone - Orders closed! Invoicing/revision time  (Read 558072 times)
Offline gbohn
Re: [GB] Klaxon! The RA2.0 clone
« Reply #600 on: Thu, 17 January 2013, 19:08:35 »
Hi;
  Could you please add to my order:
1 Red on Gray Modifier Set
1 Red on White 17key Set
  Thanks.
Offline Larken
« Reply #601 on: Thu, 17 January 2013, 19:52:36 »
I double checked my order and I realised that I must have keyed it in wrongly on the form. Tj, could you change my order in the spreadsheet? minus WoR 17 Key and add RoW 17 Key. Thanks.
| Ergodox #1 | Ergodox #2 |
Offline tjcaustin
  • King Klaxon
    • Buy stuff
« Reply #602 on: Thu, 17 January 2013, 20:09:41 »
Start collecting money already Mr. Tjcaustin!  And set a deadline/order date ASAP. :)
2nd of February, no?
This. The only thing that may have an extension is RoG stuff, but I'll wrap that into whatever I decide to do next if so and not delay this even further.
Go on then, I'll tip RoG Mods up to 50 - if you could append 1 x RoG Mods to my order that would be excellent tj!
Done
Hi;
  Thanks.
Done
Done
Offline la3195
« Reply #603 on: Fri, 18 January 2013, 05:11:31 »
Hi guys n gals,
Forgive me as I am new to all this but can I get my hands on a set of these Red on White keycaps to fit my Filco TKL ISO layout keyboard? Any help much appreciated.  :)
Ta
L
Offline redeye
« Reply #604 on: Fri, 18 January 2013, 05:24:28 »
Hi guys n gals,
Ta
L
you will have to specify what it is that you need. On the 1st post of the thread there is a iso set available and a link to illustrate what keys
 are included.
My bad, the ISO set link is missing. I'm sure i've seen it some where on here.
To get the keys to match up how you like you will probably need to purchase a number of sets in certain colours i.e WoR iso set, RoW base set and a WoR modifier set.
Hope this helps.
« Last Edit: Fri, 18 January 2013, 05:31:36 by redeye »
Offline la3195
« Reply #605 on: Fri, 18 January 2013, 05:48:21 »
Hi guys n gals,
Ta
L
 are included.
Hope this helps.
Hi redeye, thanks for taking the time to reply.  I've gone over the first post more thoroughly this time and managed to order some keys.
Cheers
L
Offline Emmiya
« Reply #606 on: Fri, 18 January 2013, 07:13:19 »
Just updated from poker to pure, and realised I'll need a shorter right shift key So I guess i'll be buying a tsangan kit :)
So my order should now be:
RoW Base
RoG Mod
RoG Tsangnan
Cheers <3
« Last Edit: Fri, 18 January 2013, 07:23:53 by Emmiya »
Offline whiskytango
  • Don't touch the trim
Re: Re: [GB] Klaxon! The RA2.0 clone
« Reply #607 on: Fri, 18 January 2013, 07:24:19 »
Offline LechnerDE
« Reply #608 on: Fri, 18 January 2013, 11:17:09 »
1st Post and 1st Buy here  ;D
I am really excited and hope my first group buy goes well!
Just out of curiosity since I am new here (to the German members out there):
Has there ever been a group buy that featured the specific Germany Layout with all the Umlauts 'n' stuff??
Offline tjcaustin
  • King Klaxon
    • Buy stuff
« Reply #609 on: Fri, 18 January 2013, 11:25:24 »
Only one I know of is Round4.
RoW Base
RoG Mod
RoG Tsangnan
Cheers <3
And done.
Hi guys n gals,
Ta
L
 are included.
Hope this helps.
Cheers
L
The only problem will be that the ISO kit looks to be only getting ordered in WoR.
RoG tsangan will definitely be ordered now, hooray.
« Last Edit: Fri, 18 January 2013, 11:49:20 by tjcaustin »
Offline la3195
« Reply #610 on: Fri, 18 January 2013, 12:05:56 »
Hi guys n gals,
Ta
L
 are included.
Hope this helps.
Cheers
L
I can live with that! :)
Ta
L
Offline tauburn
« Reply #611 on: Fri, 18 January 2013, 19:19:18 »
so what are the prices looking like at this point?
« Reply #612 on: Fri, 18 January 2013, 19:20:26 »
Tj keeps them updated in the OP
Offline tauburn
« Reply #613 on: Fri, 18 January 2013, 20:02:17 »
oh god. now i understand what the arrows mean.
Offline tjcaustin
  • King Klaxon
    • Buy stuff
« Reply #614 on: Fri, 18 January 2013, 20:05:31 »
I forgive you only because of your Ron Swanson avatar.
Offline Emmiya
« Reply #615 on: Fri, 18 January 2013, 22:50:59 »
Got bored and tallied up the orders, $20,419 so far :p
Surely that would be enough for SP to give you some leeway and create the RoG base for those who ordered it, assuming it doesn't make the 10 set order.
Offline tauburn
« Reply #616 on: Fri, 18 January 2013, 23:24:16 »
just to clarify, this picture is what a WoR base kit + RoW modifier kit gives me right?
Offline oluf
  • formerly olaph
« Reply #617 on: Fri, 18 January 2013, 23:29:40 »
That's a RoW base w/ WoR mods... First color shot is specified first. ;)
Offline tauburn
« Reply #618 on: Fri, 18 January 2013, 23:34:33 »
ok thats actually what i meant. well whatever now i know my order is correct. thanks
Offline okooko
  • afk.
« Reply #619 on: Fri, 18 January 2013, 23:55:48 »
I believe the above is incorrect.
The 6 key cluster above the arrows would be in the mod set and hence will be WoR and not RoW as in the picture.
Offline tauburn
« Reply #620 on: Sat, 19 January 2013, 01:09:57 »
yes. you're correct.
Offline redeye
« Reply #621 on: Sat, 19 January 2013, 12:27:34 »
Isn't there 2 mods  and 1 base needed for this pic?
Offline inteli722
« Reply #622 on: Sat, 19 January 2013, 12:36:15 »
I'm sad that I have to get a new mouse (and that my other keyboard's a Leopold)...Otherwise I might order 2 full sets...
Waiting for: Phantom Plate
Offline duq
  • Connoisseur
« Reply #623 on: Sat, 19 January 2013, 13:10:55 »
No, because you would only need RoW base and WoR modifiers. Base kit includes the modifiers and alphas.
Offline redeye
« Reply #624 on: Sat, 19 January 2013, 15:14:36 »
Oh ok, its just that the base set illustration link on the first post does not contain the modifiers.
http://keycapsdirect.com/pdfs/baseset.pdf
Offline duq
  • Connoisseur
« Reply #625 on: Sat, 19 January 2013, 16:14:54 »
! Oh I guess you're right. I was mistaken I'm sorry. This is my first GB where it's like this.
Offline duq
  • Connoisseur
« Reply #626 on: Sat, 19 January 2013, 21:29:24 »
TJ,
Can you please change my order to this:
1x RoW base
1x RoW tsangan
1x RoW modifier
1x WoR base
Wanted to spread the cost saving love for everyone since the RoW base set plateaued.
Order up everyone!
Offline tjcaustin
  • King Klaxon
    • Buy stuff
« Reply #627 on: Sat, 19 January 2013, 21:30:36 »
TJ,
1x RoW base
1x RoW tsangan
1x RoW modifier
1x WoR base
Order up everyone!
Done.
« Reply #628 on: Sat, 19 January 2013, 22:15:11 »
Tj,
Could you add a WoR Tsangan kit to my order please?
Offline luckynet
« Reply #629 on: Sun, 20 January 2013, 01:39:45 »
hey man i kinda double ordered. can you delete the earlier one. these are what i want to order
WoR base
RoW modifiers
RoG base
RoG modifiers
RoG ISO
Realforce 104U - HHKB Pro 2 dental band - HHKB Pro 2 Hasu's bluetooth controller - CM novatouch silent mod - Royal Kludge Topre clones
Filco Magestouch 2 Brown - Duckyshine 9008s Brown - QFR white - Plum MX 96 Blue - KBT Race Red - SS 7G Black - Poker blue - ducky shine 69
IBM Model M SSK
Matias quiet pro - V60 matias clicky
Offline akuJIWA
  • Lock 'N Load!
« Reply #630 on: Sun, 20 January 2013, 01:43:23 »
Does the Tsangan kit contain 1.5/1/7 mods?
The Cheat - B/R/B ; Clear switch with 62g springs
quit
Offline tjcaustin
  • King Klaxon
    • Buy stuff
« Reply #631 on: Sun, 20 January 2013, 01:49:41 »
Yessir
WoR base
RoW modifiers
RoG base
RoG modifiers
RoG ISO
Tj,
Done and done.
Offline akuJIWA
  • Lock 'N Load!
« Reply #632 on: Sun, 20 January 2013, 01:53:57 »
Ordered the right one then!
quit
Offline Lighthouse1
« Reply #633 on: Sun, 20 January 2013, 02:27:40 »
Yessir
WoR base
RoW modifiers
RoG base
RoG modifiers
RoG ISO
Tj,
Done and done.
Hi can the ISO kit come in RoG? I thought it was just in one colour indicated in post 609. Just wanted to check as would like both. 8).
Offline GeorgeK
« Reply #634 on: Sun, 20 January 2013, 02:56:23 »
I was under the impression that it's only going to be one colour (and that colour would, more than likely, be WoR)
Offline megaforce
« Reply #635 on: Sun, 20 January 2013, 03:23:41 »
How should I go about modifying my order?
Corsair K63 Wireless | Razer Huntsman Elite
Hokusai | Ogre| Yohane | Mc65 | Kaze | RBB
Former: LZ MX | LZ FE | LZ CLS TKL Silver |LZ CLS TKL Gray| LZ St | V.EA | Blackbird | LSV3 | OctagonV2 | Norbatouch | X60 | TX84 | Kyuu | SSK | 268.1| Jane CE | Corsair K95 | X60R | HHKB JP x JS HiPro | 910 CE |Nunu |Nunu FE | Jane V2 CE|Jane V2| RS (TKL)
Offline GeorgeK
« Reply #636 on: Sun, 20 January 2013, 03:25:05 »
Just post in here and tj will alter it when he sees your post :)
Offline MadScientist46
  • Snaged his first CCs -> HappyScientist now ^_^
« Reply #637 on: Sun, 20 January 2013, 18:13:53 »
Or PM him, that always worked out for me.
Noppoo Choc mini MX-Reds | KBT Pure MX-Reds/Green LEDs
« Reply #638 on: Sun, 20 January 2013, 18:49:22 »
Tj,
Done and done.
Thank you kind sir ^_^.
Offline Saclet
« Reply #639 on: Wed, 23 January 2013, 02:43:38 »
Hi, can you add RoW 17 key set to my order please. So my order will be RoW (Base) + WoR (Mod) + RoW (17 key). THanks.
Offline Sephiroth
« Reply #640 on: Wed, 23 January 2013, 05:55:49 »
Just want to let you know, I made a mistake that I had oerdered two , I mean there was a duplicated one, plz cancel the first one i ordered ,thx!
Offline phx
« Reply #641 on: Wed, 23 January 2013, 15:13:23 »
question.
what's the red like for this set compared to RA2? is it darker or lighter?
It's RBV for RA2 and this is RDD
Offline tjcaustin
  • King Klaxon
    • Buy stuff
« Reply #642 on: Wed, 23 January 2013, 15:37:55 »
question.
RDD is the more uniform replacement for RBV, there will be less hue differences between the caps and will look indiscernible from RBV according to SP reps.
Done
Fixed
« Last Edit: Wed, 23 January 2013, 15:44:44 by tjcaustin »
Offline phx
« Reply #643 on: Wed, 23 January 2013, 17:08:11 »
so it's exactly the same as RA2 except with a better red.
recently bought a set of RA2 thats why I was wondering about the difference
I could use another set of red caps :p
Offline tjcaustin
  • King Klaxon
    • Buy stuff
« Reply #644 on: Thu, 24 January 2013, 15:11:26 »
so the good news about the recent sherry/gmk drama is that I finally got MOQ and pricing.
400 sets at ~$80 plus shipping and what not. the question is now, as we're at approximately half that, do we change into a gmk order, include Dt and any other forum/business interested or just keep it through sp?
 discuss.
« Reply #645 on: Thu, 24 January 2013, 15:13:18 »
 discuss.
I don't think I'll be in this buy, but I would like to say my two cents. I think the biggest problem is the time it would take to get this set made, plus the cost is much more. Maybe create a poll so the people in this buy can give you some thought.
Offline tauburn
« Reply #646 on: Thu, 24 January 2013, 15:17:25 »
If the price isn't going to go down any further, can i just send you the payment now so that i don't have to worry about doing it in the future?
Offline Leewei
« Reply #647 on: Thu, 24 January 2013, 15:18:44 »
Interesting. I think gmk would produce better quality caps (thick abs) and also with the cherry font it makes it much more appealing. However since following this thread the prices have been looking amazing! There are currently 322 base sets being ordered. Does the moq of 400 count include the different options? like WOR and ROW? or is it like a mix of ROW with WOR modifiers? and does the price include tsangan/iso/numpad?
Filco Majestouch 2 Beige TKL with MX Reds
Qsenn dt-35
Offline whiskytango
« Reply #648 on: Thu, 24 January 2013, 15:19:44 »
 discuss.
What does the GMK set include?
Edit: Regardless, I think my vote is stick with SP. Who knows how long it would take to get to the 400 moq?
« Last Edit: Thu, 24 January 2013, 15:22:06 by whiskytango »
« Reply #649 on: Thu, 24 January 2013, 15:42:43 »
Just to give my opinion:
The prices that were reached for SPs sets look freaking amazing to.
Prices from GMK on the other hand seem to be pretty spicy, especially for non-EU located members. I'm from Germany though, but a lot of you aren't.
With GMK, I assume every color combination would have its own MOQ. The time we would have to wait for this set to be produced if this went through GMK would also be a big downer for me, since I really (and I really mean it ;D) cant wait much longer for these babies....
Since its standard sets and standard font for SP, there shouldn't be big screw-ups, either. Sometimes SPs qc might be a reason to consider alternatives, but in this case, I think we should be safe. (To be fair, the last few errors I read about were fixed by them pretty fast and easy!)
Thats why I would definitly choose this set to be made by SP.
(Another reason for SP is that I already have a WoR Mod kit, which would look odd with the base set having Cherry font  :p )
Edit: TJ, in case this goes through SP, did you think/ask Melissa about a pre-sorting-fee, like other GB-threads proposed? Otherwise you might be busy for weeks... :D
« Last Edit: Thu, 24 January 2013, 15:51:25 by MadScientist46 »
