Author Topic: How to test functionality of a keyboard (when buying used)?  (Read 3219 times)
Offline ShangMingg
« on: Thu, 08 November 2012, 21:33:43 »
I believe that I've found a deal that may be to good to be true, involving a used mechanical keyboard (a few weeks old).
Is there any way to guarantee that the keyboard works? I'll bring my laptop to test the basic functionality of the keys, of course, but are there other methods such as some kind of software or specific physical keystrokes I can use to test?
Offline jeroplane
Re: How to test functionality of a keyboard (when buying used)?
« Reply #1 on: Thu, 08 November 2012, 21:38:45 »
One popular key testing application is Aqua Key: http://geekhack.org/index.php?topic=34670.msg641440#msg641440
My signature hasn't changed since 2012. I should really update it.
Offline Skull_Angel
« Reply #2 on: Thu, 08 November 2012, 21:40:24 »
Could use Aquakeytest; you need to physically actuate the keys, but it'll record which keys you've pressed if they register (on-screen display).
edit: beaten to it!
