Author Topic: Remapping ctrl+something or alt+something  (Read 1835 times)
Offline rainbowshy
« on: Thu, 08 November 2012, 22:01:40 »
Hi geekhackers :) <3
I'd like to make the F1-F6 keys on my Filco into media keys (my previous keyboard, a MK-50, worked this way: Fn + F1=mute, F2=VolDwn, F3=VolUp, F4=play/pause, F5=previous & F6=next). Now, the Filco doesn't have an Fn key, but ctrl or alt would work just as well, I believe.
Achieving this by running a process is just not acceptable to me (AutoHotkey does this, I believe). Is there a way to do this with registry editing? Can it be done at all?
Thanks in advance, and sorry about the subject -- I'm not at my brightest at 5AM. Cheers!
Filco MJ2 TKL MX Brown | QPad MK-50 MX Red
Offline alaricljs
  • I be WOT'ing all day...
Re: Remapping ctrl+something or alt+something
« Reply #1 on: Thu, 08 November 2012, 22:19:38 »
You cannot do combo mapping in the registry.  W/ AHK or similar you can get what you're looking for but it requires that the program be running to catch the key presses.
Filco w/ Imsto thick PBT
Offline rainbowshy
« Reply #2 on: Thu, 08 November 2012, 22:48:03 »
That's what I feared. Thanks for the help.
