Author Topic: Need Help in deciding which keyboard to buy  (Read 1286 times)
Offline Sully
« on: Tue, 13 November 2012, 19:39:27 »
I'll get straight to the point:
I'm deciding between the
Ducky TKL http://mechanicalkeyboards.com/shop/index.php?l=product_detail&p=165
KBT Race http://mechanicalkeyboards.com/shop/index.php?l=product_detail&p=145
or the CM Quickfire Rapid
Or any other suggestions that you guys might have. I'm certain I want either MX Brown or Blue switches and, as you can tell, backlighting is a huge plus for me.
Also, I heard that the KBT Race has lots of backlighting issues and I was wondering if this was true? If that's the case, I'll most likely go with the Ducky TKL.
Offline pitashen
Re: Need Help in deciding which keyboard to buy
« Reply #1 on: Tue, 13 November 2012, 20:36:35 »
I would narrow down the choices down to: CM vs Quack!
« Reply #2 on: Tue, 13 November 2012, 20:44:51 »
Don't know about the Race, but the Ducky is a good solid board (I have two Shine version 1's).
Offline WhiteFireDragon
    • youtube
« Reply #3 on: Wed, 14 November 2012, 05:30:44 »
Some of the Race has control quality issue. Between CM quickfire vs Ducky, it's really up to you how bad you want LED backlit t justify the price difference.
