Author Topic: dolch pac 62 keyboard ps2 converter?  (Read 4411 times)
Offline rayuki
  • RAAAAAAR
« on: Wed, 14 November 2012, 01:06:42 »
can anyone tell me what format dolch boards use and if there is a way to make a ps2/usb converter for it (or buy one)
Re: dolch pac 62 keyboard ps2 converter?
« Reply #1 on: Wed, 14 November 2012, 10:45:21 »
I made a new cable for my Dolch Pac 62 keyboard and then I wrote about it on the Deskthority Wiki. :)
All keyboards speak the PS/2 protocol. The PAC-60 has a detachable PS/2 cable. The PAC-61 and upwards have a instead a cable with a (telephone-style) modular connector; it is not directly detachable from the keyboard, but ends in a modular connector inside the keyboard's case.
Keyboards without trackpoints have a 4P4C connector. The pins are GND, +5V, kb data, kb clock (in order on the keyboard's side). Dolch PAC-65 keyboards with trackpoints have a larger modular connector and cable.
Offline IvanIvanovich
  • Mr. Silk Underwear
« Reply #2 on: Wed, 14 November 2012, 10:50:54 »
I just attached a normal ps/2 cable internally on mine direct to the pcb. Unless you need to keep the original cable to use with a PAC unit, there is no reason not to do the permanent mod to standard ps/2.
Offline SmallFry
« Reply #3 on: Wed, 14 November 2012, 11:08:26 »
Meh, what about using it on the actual Dolch Pac? Nostalgia?
Offline blighty
« Reply #4 on: Wed, 14 November 2012, 11:42:27 »
Would soldering a USB cable work the same way, or would a ps2 to usb adapter need to be put inline?
LZ ergo (MX silent red) | JER - A06 (MX silent black-red springs) | Duck Lightsaver V2 (MX red) | Duck Octagon V2 (gateron clear) (lifted pads) | Duck Orion V2 (gateron red) | TKC 1800 (gateron silent reds) | Mistel MD770 (MX red with GMK silencing clips) | Realforce R2TSLA-US4-IV | Realforce R2TLSA-US4-BK | TX 75 (gateron clear) | KBDFANS 75 ("vintage" MX blues) | Kinesis Freestyle Pro (MX red) | MS Surface Ergonomic | MS Natural Ergonomic Keyboard 4000 | Filco Majestouch 2 TKL (MX black) | Phantom (Filco case) ("vintage" MX blacks | Spr1t 75% PCB x 2 (MX black and gateron clear) | Cherry G80-1865 (MX browns with black springs)
Offline SmallFry
« Reply #5 on: Wed, 14 November 2012, 11:49:33 »
PS/2 inline. Ripster had done it with his M. Just tear aprart a blue cube and put it inline. I think he still has the pictures of you check his imgur.
Offline rayuki
  • RAAAAAAR
« Reply #6 on: Thu, 15 November 2012, 05:33:17 »
thanks heaps both great ideas i'll have a look.
i have a heap of ps2/usb adapters, could i just rip one of those apart?
was gonna cost me over $100 to get the whole unit shipped to australia, so i just go the keyboard. hell i would have loved to have used it on the pac lol.
i also found this
http://www.ebay.com/itm/ws/eBayISAPI.dll?ViewItem&item=110621041896
i wonder if they have an adapter like that but in reverse?
« Last Edit: Thu, 15 November 2012, 05:39:43 by rayuki »
Offline rainb1ood
  • so pretty so plastic
« Reply #7 on: Thu, 15 November 2012, 06:06:25 »
I made a DIY using a phone line splitter and a PS/2 cable from a Cherry G81.
It looks messy but it works.
Credits to this thread for the help
« Last Edit: Thu, 15 November 2012, 06:12:19 by rainb1ood »
Offline rayuki
  • RAAAAAAR
« Reply #8 on: Thu, 15 November 2012, 07:07:29 »
nice one looks like the quickest dirtiest solution so far to get it working to have a type on it lol.
