Author Topic: keyboard with USB interface still usable through PS/2 interface  (Read 2309 times)
Offline dimm0k
« on: Wed, 14 November 2012, 16:29:53 »
Originally I was looking at the Ducky 9008S keyboard, which gives the option to connect via USB or PS/2, but now that it's discontinued with nowhere selling these keyboards I'm looking at its replacement, the Ducky Shine II.  Unfortunately this keyboard is USB only so I was wondering if it's at all usable on computers with only the PS/2 interface.  I would like a keyboard that would allow me to use both in case the need to ever troubleshoot a machine arises and I have no PS/2 keyboards around.
Offline dimm0k
Re: keyboard with USB interface still usable through PS/2 interface
« Reply #1 on: Thu, 15 November 2012, 10:23:24 »
anyone know the answer to this?
Offline esoomenona
  • Gnillort?
« Reply #2 on: Thu, 15 November 2012, 10:45:52 »
You could buy a USB to PS/2 adapter. Should work just fine.
Offline dimm0k
« Reply #3 on: Thu, 15 November 2012, 11:10:57 »
Damn, I was under the assumption that if it stated USB as the interface that converting it to PS/2 with an adapter would not work with keyboards.  So when they say USB and PS/2, they're merely including the necessary adapter for both interfaces?
Offline esoomenona
  • Gnillort?
« Reply #4 on: Thu, 15 November 2012, 11:12:37 »
Usually so. I know my daskeyboard and CM Storm QFR both came with a USB to PS/2 adaptor.
Offline Shadovved
  • King of Stickers (and GBs)
« Reply #5 on: Thu, 15 November 2012, 11:13:30 »
I would assume, yes.
They are including the adapter for you, my Filco says PS2 or USB too, but its USB and came with an adapter :D
Offline esoomenona
  • Gnillort?
« Reply #6 on: Thu, 15 November 2012, 11:14:50 »
Also, what gave you the assumption that it wouldn't work? Maybe I'm missing something? I was using my das via PS/2 because it allowed for the NKRO.
Offline urbanus
« Reply #7 on: Thu, 15 November 2012, 13:00:50 »
A passive adapter?  They work in most cases because the keyboard can detect that it's connected via PS/2 and so will talk that protocol.  However there are some notable exceptions, like Unicomp's USB boards which don't do that: strictly USB only.
