Author Topic: Anyone know of any left-handed keyboards?(doesn't have to be mechanical)  (Read 4999 times)
Offline TheQsanity
  • SmallFry Lovin'
Does anyone know of a left-handed keyboard?(enter on the left side)
QWERTY would be YTREWQ
Not the number pad on the left side, like a full mirror.
SmallFry! <3
Offline Dgsbllx
Re: Anyone know of any left-handed keyboards?(doesn't have to be mechanical)
« Reply #1 on: Fri, 16 November 2012, 03:40:35 »
Would be quite interesting to see one of these. I have only seen the keyboards with the arrows/numpad on the lefthand side but the keyboard still remains qwerty.
Good luck finding
Offline laffindude
« Reply #2 on: Fri, 16 November 2012, 05:17:00 »
http://www.dsi-keyboards.com/dsi-left-handed-usb-keyboard-with-cherry-mechanical-key-switches.aspx
I don't know any mirror boards.
Edit again. What is the utility of doing a mirror board? Enlighten me please. * I am a lefty, but I don't understand.
« Last Edit: Fri, 16 November 2012, 05:22:22 by laffindude »
« Reply #3 on: Sat, 17 November 2012, 01:04:39 »
Never even heard of a rumour of one.  numpad on the left, yes, but the Enter key still on the right of the main cluster.
Offline TheQsanity
  • SmallFry Lovin'
« Reply #4 on: Sat, 17 November 2012, 02:10:24 »
Just for kicks. I am sure there can be lots of fun and uses for them.
SmallFry! <3
« Reply #5 on: Sat, 17 November 2012, 02:56:16 »
Apart from no-one being to type on them, and needing a custom PCB, at least the standard key caps should fit.
Offline rootwyrm
  • The Hands of Steel
    • My Website!
« Reply #6 on: Sun, 18 November 2012, 03:39:06 »
Well, if you could relocate the keypad side, a Model M would be a good modification candidate for this. Dunno if you all looked lately, but the M's layout is almost perfectly split. And none of those keys have stabilizers to worry about, either. The backspace to `1 swap might be a bit tricky though - don't think there's a matrix line to the 'dead' stem there.
"I remain convinced I am the only person alive who has successfully worn out an IBM Model M mechanically."
Daily Drivers: Adesso 625 (NPKC PBT / Kailh Blue), Rosewill RK9000V2 (KC PBT / MX Brown), 1994 Model M13, Sun Type4, and the rare IBM 1394540.
Offline wetto
  • Brazil's Keyboard Enthusiasts Representative
    • Portuguese Mechanical Keyboard Guide
« Reply #7 on: Sun, 18 November 2012, 08:31:41 »
Am I the only right handed guy who would really enjoy having the numpad on the left? I mean, this surely reduces the distance between the keyboard and my mouse (since it's on the right) and the numpad is still there, but on a less annoying place.
Plus, make it completely configurable and you get yourself macro keys, just like that piece-of-failure called Aziotech Levetron Mech 4/5.
My collection:
Mice: Logitech G602, CM Storm Recon, CM Storm Spawn, Razer Naga, Ozone Radon Opto, Corsair M60, Tesoro Gandiva, CM Storm Alcor, Mionix Naos 8200.
Keyboards: Matias Secure Pro, Matias Mini Quiet Pro, custom modded Metadot Das Keyboard Model S Professional Silent (MX Brown, Costar), CM Storm Trigger (MX Brown), Noppoo Choc Mini (MX Red), Tesoro Lobera G5NFL Supreme, CM Storm Devastator.
Soon: CM Storm Quick Fire TK (MX Brown), CM Storm Trigger Z.
Boards I don't own anymore: CM Storm Quick Fire Rapid (MX Black), Logitech K800 (Membrane), Logitech G710+ (MX Brown), Thermaltake Meka G-Unit (MX Black), Corsair K70 (MX Red).
Mice I don't own anymore: Logitech G9x MW3, Corsair M65, Logitech G700, Roccat Kone Pure.
Offline rootwyrm
    • My Website!
« Reply #9 on: Sun, 18 November 2012, 13:28:12 »
http://www.fentek-ind.com/modular.htm
Problem is the L-Shaped enter key. You can't swap that one for the mirror. (That's why I brought up the M; most you'll find have the two-stem short Enter key.) Otherwise looks like a solid candidate, if available in ANSI instead of ISO.
Also just for giggles, I swapped my enter and caps lock keys on an M. Yeah, perfect match.
« Reply #10 on: Mon, 19 November 2012, 00:04:07 »
I'd say (After the DSI LH keyboard ofcourse) the best you get are symmetrical keyboards like the kinesis advantage and the ergoDOX
Offline quake4mhg
« Reply #11 on: Thu, 22 November 2012, 01:28:11 »
Your not alone. I'm a right hand guy, but enter numbers with left hand for years. Always thinking keyboard design is totally wrong (no offense). I've been looking for left-handed backlit MX black switch years. Now using KBT Race with Filco numpad (with autohotkey). I guess I'll be stuck with this setup till the end of computer keyboard peripheral  :mad:
Offline TotalChaos
  • Indy Game Coder
« Reply #12 on: Thu, 22 November 2012, 04:28:41 »
Why does the topic ask about left handed keyboards?
The OP is asking for a mirror image keyboard, which is something completely different.
Or do left handed people really see everything as a mirror image of what right handed people see?  :eek:
Also, do you want the legends on the keys to be in mirror image also?
At least H M O X A W T U I  V : ! | *-_=+ would look exactly the same on this new keyboard as on a regular one but <> would be really confusing.  :p
What would COLEMAK layout look like on this new mirror image keyboard?  I guess it would just be mirror imaged along with the keys.
