Author Topic: Purple LEDs  (Read 5760 times)
Offline WhiteFireDragon
    • youtube
Purple LEDs
« on: Fri, 16 November 2012, 04:25:40 »
I didn't realize purple LEDs were so hard to find. Only ones I could source are these Xicon 351-3314-RC, but they're just too dim at only 110mcd. All other major online electronics parts stores do not have any other purple ones. Any help on sourcing these would be much appreciated. The catch (and also what makes them hard to find) is that they must be in 3mm T1 size, through-hole, and sold/shipped from within the US because I need these ASAP. Nearly all other LEDs are from China or Hong Kong, takes too long to receive them.
A workaround I can think of is to just get UV LEDs in the low 400nm range instead of the high 300nm, but this won't be very bright, and won't be true purple.
Offline m00nshake
Re: Purple LEDs
« Reply #1 on: Fri, 16 November 2012, 06:24:24 »
I also was thinking about having purple leds on my Kmac but I also couldn't find anything. Since Ducky has a board with purple leds this has to be available somewhere. I too would be interested in finding out where to get them for future builds. Thanks for bringing this up.
Ducky Shine II w/ Green LEDs | Das Professional | Italian Red Filco Ninja Tenkeyless | Unicomp Wildcats Buckling Spring | My Heatware :)
Re: Purple LEDs
« Reply #2 on: Fri, 16 November 2012, 06:34:57 »
I bought these UV/Purple (peak 620-625nm) ones from a Hong Kong seller on eBay. They claim to be 6000mcd, but they are really not that bright to me in the visible spectrum.
« Last Edit: Fri, 16 November 2012, 06:36:56 by jdcarpe »
Offline samwisekoi
  • MAWG since 1997
    • Tweet samwisekoi
Re: Purple LEDs
« Reply #3 on: Fri, 16 November 2012, 06:36:43 »
I "needed" some pink LEDs for a case mod I did on some Lian Li power/reset switches.  They were hard to find, because mostly the ones called Pink were really Purple in output color.
Anyhow, I bought mine form a guy in the UK, but along the way I found two good places to look:
1) Model train suppliers.  They use LEDs for all sorts of little lights.
2) Search for Pink as well as purple -- you might luck out that way.
 - Ron || samwisekoi
Offline engicoder
Re: Purple LEDs
« Reply #4 on: Fri, 16 November 2012, 09:13:16 »
Offline MMB
Re: Purple LEDs
« Reply #5 on: Fri, 16 November 2012, 10:52:40 »
Purple LED's are very easy to find on ebay, mainly from China.
It will be nearly impossible to find a super bright purple (UV) LED. Not sure why that is exactly, but I have been through several different kinds.
Offline SmallFry
Re: Purple LEDs
« Reply #6 on: Fri, 16 November 2012, 10:54:04 »
I'm sure that Digikey has them...
    • youtube
Re: Purple LEDs
« Reply #7 on: Sat, 17 November 2012, 04:16:49 »
What about the NightFire ones:
http://www.amazon.com/NightFire-Clear-PURPLE-pieces-Resistors/dp/B008D5NKRY
Thanks for the link. I actually saw those too, but there are absolutely no electrical rating on those, so I didn't want to risk getting those. But I may end up having to get those as a last resort.
It's because the UV range of the wavelength spectrum is not in the visible color range. It might barely touch the 400nm range, but not really enough to be considered a real color.
Nope, mouser and digikey had none.
Offline bpiphany
Re: Purple LEDs
« Reply #8 on: Tue, 20 November 2012, 01:25:42 »
Remember to be careful about what you really get. UV light isn't that great for your eyes... And if they really do emit most of their power you are not even going to notice what is happening when you go blind =P (Yes I am pulling that a bit out of my ass, but I am sure it's not going to be good at least ; )
Offline SmallFry
Re: Purple LEDs
« Reply #9 on: Wed, 21 November 2012, 08:33:19 »
Found this... looks like purple is right on the edge of the color spectrum that you can get LEDs in.
Offline bpiphany
Re: Purple LEDs
« Reply #10 on: Wed, 21 November 2012, 08:39:51 »
There are proper UV LEDs, so it's not quite true purple is on the edge of what is possible. I'd say that graph shows there is no great amounts of UV or IR in their white LEDs. It may be hard to produce good LEDs with visible purple color, I have no idea. And I still want to urge everyone to be careful with UV light.
http://www.lumex.com/images/Lumex_UV_LEDs_6WV.pdf
« Last Edit: Wed, 21 November 2012, 08:41:48 by bpiphany »
Offline SmallFry
Re: Purple LEDs
« Reply #11 on: Wed, 21 November 2012, 08:58:47 »
Me too, I wouldn't use UV LED's myself... perhaps a company would make a purple lensed LED.
Offline alaricljs
  • I be WOT'ing all day...
Re: Purple LEDs
« Reply #12 on: Wed, 21 November 2012, 09:01:11 »
Someone makes it cuz Ducky's got it... be damned if I can find one from the usual places tho.
Filco w/ Imsto thick PBT
Offline SmallFry
Re: Purple LEDs
« Reply #13 on: Wed, 21 November 2012, 09:09:54 »
Buy a Ducky and pull the LEDs. :P
    • youtube
Re: Purple LEDs
« Reply #14 on: Wed, 21 November 2012, 18:33:02 »
There were a few people that mentioned their ducky purple LEDs were more pink than purple. I just got my purple LEDs in today, so I'll see what kind of purple hue it is when I get home (or maybe even pink too).
