Author Topic: KBT Race keycaps size  (Read 4171 times)
Offline netdevil
« on: Sat, 17 November 2012, 04:54:40 »
First of all thanks in advance for any replies  ;D
I am pretty new to the mechanical keyboard scene and I am trying to find replacement keycaps for some of the odd size keys on the race. However I did a search and couldn't find any info on those and my board is not here. It be helpful if anyone with the race chime in and tell me the size of the shift, caps lock, ctrl/alt keys etc.
Offline YoungMichael88
  • HHKB Wannabe
« Reply #1 on: Sat, 17 November 2012, 05:29:57 »
I think all your left hand shift, caps lock and mods are standard size the only odd ones are the right shift, esc, and Del keys. Your arrows and right shift are the same size as normal mods and your enter key and backspace are also standard size. There is one more key that is an odd size and its the backward slash (\ | ). I might be forgetting something. Hope this helps.
EDIT: I have also had no luck finding those odd shaped keys for my race either.
« Last Edit: Sat, 17 November 2012, 05:31:56 by YoungMichael88 »
Offline jeroplane
Re: KBT Race keycaps size
« Reply #2 on: Sat, 17 November 2012, 05:34:37 »
The left side is all standard:
Left Alt, Ctrl, Win - 1.25
Left Shift - 2.25
Left Caps - 1.75
The right side is different:
Right Shift - 1.25
Right Alt, Ctrl - 1
Arrows - 1.25
End - 1.25
The rest of the board is standard, although the issue with matching row profiles will be difficult...
My signature hasn't changed since 2012. I should really update it.
Offline netdevil
« Reply #3 on: Sat, 17 November 2012, 05:38:58 »
Wow you guys are awesome that was some double quick reply  :eek: Now I can get some modifier keycaps
thanks jeroplane and Youngmichael. ;D
Offline LollyWater
« Reply #4 on: Sat, 17 November 2012, 11:46:06 »
Not PBT caps and they're also blank but they're the best I can find.
http://www.wasdkeyboards.com/index.php/products/individual-blank-keycaps.html
