Author Topic: MX Boards with 1.5x 1.0x 1.5x Modifiers  (Read 2830 times)
Offline metafour
« on: Sun, 18 November 2012, 09:12:35 »
Is the Cheat the only ANSI MX board that has this modifier layout or was the Phantom also able to do this layout as well? Are there any others?
Offline esoomenona
  • Gnillort?
Re: MX Boards with 1.5x 1.0x 1.5x Modifiers
« Reply #1 on: Sun, 18 November 2012, 09:25:04 »
Phantom like this? (Photo courtesy: DanGWanG)
Offline Alessandro
  • The Price Is Right
    • Alessandro's Sweet Shop
« Reply #2 on: Sun, 18 November 2012, 09:32:13 »
Noppoo Choc Mini does.
Offline jcrouse
« Reply #3 on: Sun, 18 November 2012, 10:03:03 »
The KMAC II and LZ87SE also are / will do 86 keys.
Offline jeroplane
« Reply #4 on: Sun, 18 November 2012, 10:06:31 »
GH60 will support it.
My signature hasn't changed since 2012. I should really update it.
Offline metafour
« Reply #5 on: Sun, 18 November 2012, 10:15:10 »
@esoomenona And to think I almost put in an order when the Phantom GB was still going. That's pretty sweet since it doesn't have the menu key on the right.
Definitely will be keeping an eye on the GH60 thread then since the KMAC II, LZ87SE, the Cheat and the correct Phantom will be hard to find and very expensive.
Offline SmallFry
« Reply #6 on: Sun, 18 November 2012, 11:52:48 »
Phantom isn't expensive if you do it right... ;)
Offline daerid
    • Rossipedia
« Reply #7 on: Sun, 18 November 2012, 14:12:24 »
Are phantom's still up for sale?
Offline SmallFry
« Reply #8 on: Sun, 18 November 2012, 14:53:32 »
Nope.
Offline metafour
« Reply #9 on: Sun, 18 November 2012, 17:38:55 »
What PCB layout is this?
Offline sth
  • 2 girls 1 cuprubber
« Reply #10 on: Sun, 18 November 2012, 17:40:13 »
kmac mini is 1.5, 1, 1.5, space, 1.5
Offline DanGWanG
  • Higher Standards
    • DanGWanG's Keyboard Blog
Re: Re: MX Boards with 1.5x 1.0x 1.5x Modifiers
« Reply #11 on: Sun, 18 November 2012, 17:48:49 »
PHANSI150
Offline SmallFry
Re: Re: Re: MX Boards with 1.5x 1.0x 1.5x Modifiers
« Reply #12 on: Sun, 18 November 2012, 18:43:21 »
PHANSI150
Pardon the pun...PHANSY!
« Reply #13 on: Mon, 19 November 2012, 04:36:31 »
iOne scorpious (and clones) do have 1.5 1 1.5 - 6 - 1.5 - 1 - 1 - 1.5.
Offline SmallFry
« Reply #14 on: Mon, 19 November 2012, 07:42:51 »
As do all other iOne boards. I forgot about them since I typically shy away from their boards.
