Author Topic: Cherry MY7000 HPBUS-2 (Black)  (Read 4833 times)
Offline Acetrak
  • ssk.ℜ
  • gnawm_
« on: Mon, 19 November 2012, 10:37:26 »
Offline IvanIvanovich
  • Mr. Silk Underwear
Re: Cherry MY7000 HPBUS-2 (Black)
« Reply #1 on: Mon, 19 November 2012, 11:06:43 »
Nice and cheap, but they are often shiny as a mirror.
Offline inlikeflynn
  • file not found
« Reply #2 on: Mon, 19 November 2012, 11:11:43 »
someday i'm going to go down there and try to pick out the better condition ones.....just haven't had a chance yet
----------- __o
--------- _`\<,_
BRAAP(>)/ (*)
Offline precarious
  • LOOK MOM, I'M A DRAGONZORD! DOOOO DODOODODODOODOO
« Reply #3 on: Mon, 19 November 2012, 11:58:47 »
last time i checked with them about two months ago they said they had 225 of the HPBUS models
Offline domin8r
« Reply #4 on: Tue, 20 November 2012, 08:24:18 »
Someone proxied one of these for me a while back (also from ocean-tech) and only a few keys were shiny! :)
Compaq MX-11800, Ergo Clear/Brown/Ghetto Red
Ducky 1087XM
Laser SX-25 , White SMK
Black Dell AT101W
IBM Model M 1390120 (\'86)
Cherry G80-1000, Panda Clears
« Reply #5 on: Tue, 20 November 2012, 17:01:14 »
Was that me? I think I remember it. It was just the keys, right? If it's the one I'm thinking of, he's right. The keys were in really good shape.
But I think it's probably just a matter of luck, to be honest. I have heard that contacting the seller is a way to sometimes make sure you get one that's not very shiny.
Offline placebo guy
« Reply #6 on: Tue, 20 November 2012, 21:45:26 »
I might go next Friday.  If you're up for it, let me know.  I'll check their stock for any good condition keys in case other members may want them. =)
Leopold TKL MXRed; RF 103U 55G; WASD MXBlack; Unicomp Spacesaver; AT101W; RK-9000 Blue; various Filco
Offline mickd
« Reply #7 on: Tue, 20 November 2012, 23:49:30 »
So are MY switch keycaps 100% compatible with MX switches?
Offline Acetrak
  • ssk.ℜ
  • gnawm_
« Reply #8 on: Wed, 21 November 2012, 07:50:36 »
The MY keys with stabilizers won't fit MX switches, but other keys should be fine.
Offline domin8r
« Reply #9 on: Wed, 21 November 2012, 08:49:15 »
Yeah that was you Dorkvader (:D) Just the keys indeed! They're in nice shape!
The numpad keys are worn the most, probably from use as a register. But using them for a TKL board so really didn't matter.
Ducky 1087XM
Black Dell AT101W
« Reply #10 on: Wed, 21 November 2012, 10:52:16 »
Doubleshots are 100% the same on both MX and MY boards, so is POM from all I have seen so far. Only the later pbt lasered have the incompatible stabilized keys, though they will work with costar style stabs.
Offline limmy
« Reply #11 on: Wed, 21 November 2012, 12:52:08 »
I am sure lysol meant MY7000 boards. There are some incompatible doubleshot key caps from MY8000 boards with x1.25 modifiers, in particular bottom row (control, alt, spacebar, windows). Spacebar is useless (has built in stabilizers) and other bottom row keys have off center stem.
« Reply #12 on: Wed, 21 November 2012, 13:04:01 »
Those aren't doubleshots though... the off center bottom row 1.25 keys on G81-3000/8000 are always pad print or lasered.
Offline limmy
« Reply #13 on: Wed, 21 November 2012, 13:10:52 »
Right! But from perspective a buyer without prior knowledge, they wouldn't know that those caps are not double shot.
Offline mickd
« Reply #14 on: Wed, 21 November 2012, 18:09:10 »
This might be worth mentioning, but theres a 20% off on these at the moment... price down to $7.99.
« Reply #15 on: Thu, 22 November 2012, 01:47:12 »
This basically means that here's more $20 used cherry Doubleshots, if you missed out before. If anyone needs mail forwarding, please see this topic. I can't speak for anyone else, but I'm willing to pull the keycaps off, to save on intl. shipping.
I see $9.99 + $13.21 shipping
« Last Edit: Sat, 24 November 2012, 00:45:04 by dorkvader »
Offline MissMurd3r84
  • In IRC wondering why Kmiller8 is yelling.
« Reply #16 on: Fri, 23 November 2012, 00:59:26 »
How much is the shipping to US on them? (As in how much does it show to ship to you lot in the US)
KBC Poker - Red switches. Noppoo Choc Mini - Black switches. Leopold FC700R (White) - Blue switches. Ducky YOTD - Brown switches. Razer BW - Blue switches and rusted.
Offline mickd
« Reply #17 on: Fri, 23 November 2012, 06:08:42 »
About $13-14, plus say $1 more for every additional keyboard.
You can see it if you change the shipping options on ebay to the US and put in some random post code.
