Author Topic: [Fundraiser] Black/Blue Cherry MX switch group buy  (Read 4637 times)
Offline alaricljs
  • I be WOT'ing all day...
« on: Tue, 20 November 2012, 15:48:12 »
GeekHack fund raising switch group buy.  Proceeds from this sale will go straight into the GH hardware fund.  In this I am NOT a direct representative of GH, I take sole responsibility for this sale and whatever comes of it.
$.50 - PCB blues    (MAX & MOC: 1000)
$.50 - PCB blacks   (MOC: 800, increment: 800)
$.45 - plate blacks (MOC: 3200, increment: 3200)
You pay shipping (and packaging if necessary), flat rate priority preferred.  I will also split vendor shipping to me across all orders.
Since the order requirements are in blocks I will mix and match whatever orders come in to fit the block with a preference to the earliest.  There are only 1000 blue switches, but all of them must be bought so being early is no guarantee that you will get switches.  Nice even numbers and reasonable quantities will of course help!
The PCB blacks are easier, but I don't know if interest is there, plate blacks are a little cheaper but the order requirements are harsh.
This buy doesn't happen if we don't manage to get enough interest.  If the vendor no longer has the switches available, the GB doesn't happen... and any other random reason that may come up as well ;)   No guarantees.
Filco w/ Imsto thick PBT
Offline MMB
Re: [Fundraiser] Black/Blue Cherry MX switch group buy
« Reply #1 on: Tue, 20 November 2012, 15:52:39 »
Would you consider adding other options to this? Particularly tactile grey?
Offline mickd
« Reply #2 on: Tue, 20 November 2012, 15:55:23 »
I was thinking the same thing. But I guessed you would have already asked.
Offline alaricljs
« Reply #3 on: Tue, 20 November 2012, 15:55:59 »
I can only sell what I can buy.
Offline michaelrw
« Reply #4 on: Thu, 29 November 2012, 23:06:53 »
...what is the geekhack hardware fund? hardware for who?
Offline RickyJ
« Reply #5 on: Fri, 30 November 2012, 01:53:04 »
Server hardware to keep this site running! :)
Currently GMMK Pro: lubed 68g U4T, FR4 plate, extra gaskets, etc
