Author Topic: Choc Mini Question(s)  (Read 1949 times)
Offline HRS2K
  • I love Blue!
« on: Wed, 21 November 2012, 11:29:27 »
I am new to the mod world of mechanical keyboards so like typical, I have questions. I tried to search the forum but did not find a clear answer. I am not sure if I didn't use the correct keywords or look at the correct tread.
So I am in the market for a Noppoo Choc Mini. I want to mod it with Ergo-clears (brown spring) or Panda Clears. I am not sure yet but where would I go about getting clear switches?
I also a while back I saw a very sexy looking Choc Mini in the classifies and wanted to know where I could find a case and the key caps for this mini.
8293-0
I did notice that space bar row look like 1.5x caps and the right shift key look like the size of tsangan kit.
8295-1
Can anyone get me started in the right direction?
Thanks in advance!! :cool:
« Last Edit: Wed, 21 November 2012, 15:10:18 by HRS2K »
KBC Poker (Blacks), CM Storm QuickFire Rapid (Blues), Leopold FC200RC (Blues)
Offline boost
  • BOSTMOBILE
  • NY Giants!!!
Re: MX-Mini Question(s)
« Reply #1 on: Wed, 21 November 2012, 12:15:40 »
With a Choc you'll need to desolder the switches before you can mod them. Your best bet is to camp the classified in search for the clear stem or switches.
The MX-Mini is a custom Korean Keyboard what is similar to the Choc but uses 1.5mods, 7x spacebar, and 1800 shift. You can try to camp the Korean forums for a MX-Mini but be prepared to fork up $150+
-Enzo Ferrari
Offline HRS2K
  • I love Blue!
« Reply #2 on: Wed, 21 November 2012, 15:09:46 »
i figured i would be desoldering. i gave it a 2nd look and see the difference now, thank you!. How would i go about finding caps the fit the Choc?
Offline boost
  • BOSTMOBILE
  • NY Giants!!!
Re: Re: MX-Mini Question(s)
« Reply #3 on: Wed, 21 November 2012, 16:07:00 »
You'll a combination of a base set and tsangan kit
-Enzo Ferrari
Offline HRS2K
  • I love Blue!
« Reply #4 on: Wed, 21 November 2012, 16:09:24 »
Thank you!
