Author Topic: Cheap ALPS keypads on eBay  (Read 2911 times)
Offline urbanus
« on: Fri, 23 November 2012, 23:42:58 »
Does this look like a good deal?
http://www.ebay.com/itm/260902522660
Offline boost
  • BOSTMOBILE
  • NY Giants!!!
Re: Cheap ALPS keypads on eBay
« Reply #1 on: Sat, 24 November 2012, 00:23:08 »
Nice. $15 for a alps tenkey is pretty sweet.
-Enzo Ferrari
« Reply #2 on: Sat, 24 November 2012, 00:51:03 »
It'd be a better deal if they were consistant about the keycaps. They show a Doubleshot keycap underside, but the ones are obviously not DS when viewed on the product. They look lasered.
Offline urbanus
« Reply #3 on: Sat, 24 November 2012, 04:05:33 »
Yes, I was thinking exactly the same thing!  Another give-away is that in the close-up, you don't see the same ridge around the key area you see in the other shots.  It looks like they've found a generic picture of an ALPS switch from some keyboard and put that in their listing.
Offline Caaaarrrt
« Reply #4 on: Sat, 24 November 2012, 04:35:24 »
I bought this because I was after a cheap tenkey, and I wanted to try ALPS, it's not bad at all for the price. It does have lasered keys, not double shot.
Metal Grey LZ-GH - 62g Clears | White HHKB Pro2 |KBC Poker - Lubed Reds w/ Plate and Red Imsto case | Duck PokerCM QuickFire Rapid - Blues w/ red case
Offline hluo87
« Reply #5 on: Thu, 29 November 2012, 09:56:45 »
i want to try....
Offline xavierblak
« Reply #6 on: Fri, 07 December 2012, 00:22:02 »
I picked one of these up. Figured it'd be the cheapest way to try out some Alps switches. But after playing with it for a while I popped off the keycaps and I noticed there is no alps logo on the switches so I'm guessing these probably aren't legit alps.
The feel is a very tactile click. It's stiffer than an mx blue possibly even more than a green.
Some other things to note. Is it has no feet to raise it up so it will sit pretty flat next to a keyboard that has it's feet extended. It's actually even even lower than my filco when fold the filco's feet up. It looks cheap but it feels solid enough, the keys are plate mounted so the feel is decent.
Over all I'd say it was worth the 15 bucks.
« Reply #7 on: Fri, 07 December 2012, 02:10:28 »
Pretty sure these are the same switches that are in my ALPSulator, no logo, white slider, very loud. Are they White XM's? Comparing side-to-side, mine are less than a cherry green, though.
Thanks for the info, xavierblak.
Edit: I meant comparing white xm to cherry green. I don't have any green alps.
« Last Edit: Sat, 08 December 2012, 11:24:27 by dorkvader »
Offline kaiserreich
  • HHKB Elite
« Reply #8 on: Fri, 07 December 2012, 05:34:38 »
They are very loud.
And selling for 3 times less in Taobao.
Offline xavierblak
« Reply #9 on: Fri, 07 December 2012, 11:14:48 »
Pretty sure these are the same switches that are in my ALPSulator, no logo, white slider, very loud. Are they White XM's? Comparing side-to-side, mine are less than a green, though.
Yes they do have a white stems so they are probably white xm's. The greens I compared it too are loose, I don't have them mounted on a board yet so it's a little hard to tell. But it does feel like these switches are stiffer than the greens. But with these being clones who knows how much the feel is going to vary from switch to switch anyway.
Offline korne
    • comscan
« Reply #10 on: Fri, 07 December 2012, 14:54:19 »
Bought 1 of those, wanted to try them
